pesky lil' gremlins
Old 21 Nov 2011, 08:59 am
mdskinner731's Avatar
Default pesky lil' gremlins
ok so i finally got my pt put all together ready to fire up!!! found some serious corrosion on the battery terminal leads and the main body ground! cleaned them all up pretty good! now time to crank it over... it does just that cranks and cranks with out fireing up?? with good fuel flow. timing marks still line up everywhere! and does not wanna fire up?
any guesses? crank sensor?? cam positionong sensor?? i am pretty confused!! HELP!!!! lol
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 21 Nov 2011, 09:21 am
Default Re: pesky lil' gremlins
You undo any connectors? You could've swapped connections since they reach and can connect.
Old 21 Nov 2011, 10:13 am
cruserdad1976's Avatar
thats mu guess i have heard that 2 of them will interchange but not fire
Old 21 Nov 2011, 10:51 am
any pics of the potential wiring mis-hap?? lol
Old 21 Nov 2011, 03:12 pm
or is some one able to tell me what 2 connectors i switched?
Old 22 Nov 2011, 09:00 am
ok found the wiring problem.. cam shaft sensor & the coil pack use the same electrical connector??? why or how that is i dunno?? but still i switched them around tagged the correct one for the coil and cam shaft sensor. but i still have absolutly no spark?? fuel pump cycles. has there been any broblem with the auto shut down relay?? (which controls the injectors opening and closing as well as the ignition)
!!!!!HELP!!!!
Old 22 Nov 2011, 10:22 am
Originally Posted by mdskinner731 View Post
has there been any problem with the auto shut down relay?? (which controls the injectors opening and closing as well as the ignition)
!!!!!HELP!!!!
Your asking us if there's been a problem with the ASD? Maybe you are but it's easy to check. It's the #13 fuse in the PDC under the hood.
Old 22 Nov 2011, 12:56 pm
checked all fuses in there found a blown fuse for heated seats... lol but nohting else :/
hmm... any furthere suggestions?? im at wits end with almost $1000 in to this project.
prolly tomorrow ill plug in the old mt2500 (snap-on red brick) and check all the computer functions and sensor feed-back???
dang gremlins! (main computer?) Teeter Tech & Performance Forum 4 24 Jul 2011 03:56 pm
Pesky Coolant Leak? mjb457 General Turbo Discussions 3 18 Mar 2011 01:39 pm
Electrical Gremlins SantaGuy General PT Cruiser Discussions 10 24 Sep 2009 05:01 am
New pinstripes add a lil' class BumperBob General PT Cruiser Discussions 7 06 Jul 2005 08:34 am
Gremlins? zzzhuh General PT Cruiser Discussions 1 02 Oct 2004 05:20 pm
