Timing Belt
Old 24 Nov 2011, 02:31 pm
Default Timing Belt
Howdy,
Have an 01 PT 2.4,, had to take the head off and mangled the inner timing cover so I need to replace it. Whats the BEST way to get the front engine mount off, take off the inner cover, replace it and the timing belt??
Old 24 Nov 2011, 03:09 pm
UptownSport's Avatar
Default Re: Timing Belt
HOW TO's
Old 27 Nov 2011, 03:24 pm
Originally Posted by UptownSport View Post
Yea thats out of the car,, My engine is still in
Old 27 Nov 2011, 05:00 pm
All the "How TOs" that were given to you by UptownSport are for repairing the 2.4 Ltr engine while it is still IN the car. There's a least 3 threads on changing the timing belt in that list. The inner cover should be accessed while doing that repair. The instructions should also say how to remove the engine mount.
Old 27 Nov 2011, 05:43 pm
Thanks,, Only saw the first one thats out of the car,, will check again. That inner timing cover and front mounting bracket are going to be a bitch I can tell
Old 27 Nov 2011, 05:46 pm
Yea, there's even a thread mixed in there that shows how to do the timing belt when you don't have a lift. Now that's a back breaking job.
Old 27 Nov 2011, 11:38 pm
compdr59's Avatar
Unbolt the transmission mount and drop the driver's side too. It will give you a little extra room.
Original Owner 135k
Timing Belt? squeeg2000 General PT Cruiser Discussions 2 16 Apr 2011 08:47 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
Could it be the timing belt? mbmouse Tech & Performance Forum 4 12 Jan 2009 09:01 pm
