03-up engine in a 2002 PT
Old 25 Nov 2011, 06:54 pm
Default 03-up engine in a 2002 PT
So I bought a engine from speedway motors only to find they are for 03 and up! Is there any way to make that engine work in my 02? What I heard is the crankshaft sensor is the problem. Any ideas will be very great full
Old 30 Nov 2011, 12:38 pm
Default Re: 03-up engine in a 2002 PT
Both the crank sensor and block itself have different part numbers from 2002 and 2003. The head, however, is the same.
-Chris
Old 30 Nov 2011, 02:41 pm
UptownSport's Avatar
The sensor is part of the 'NGC' (next Generation Controller) so,
you'd need that PCM, and wiring if different.
I can kinda figure out old Neon PCM's, can't help you on something that new.
My guess would be it's easier to resell engine, but guess only
Old 30 Nov 2011, 09:12 pm
TurboDucky's Avatar
You'd be better off taking that engine back and finding an '01 / '02 engine. The 2.4 out of the same year (4 Door) Stratus / Sebring is the same block.
-Gary-
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 04 Dec 2011, 07:22 pm
Yea speedway won't take the motor back because they say it was for 03 and up even though I asked they guy and he said yes! So it's for sale if anyone is interested!!! Anyhow I put the old engine back in and the codes I'm getting are P0351 and P0352. I only wanted to do the swap because the motor has over 180K
Old 05 Dec 2011, 01:16 am
Mileage doesn't make much of a difference on engines anymore.
Change time belt, water pump m a y b e e a headgasket.
Rod bearings are EZ if it starts to get a little noisy (except 2.4's have that balancer thingy)
Old 05 Dec 2011, 07:43 am
TurboDucky's Avatar
UpTownSport is right, these 2.4's are tough engines.
Those codes you are seeing reference a coil, or wiring to the coil problem.
-Gary-
2002 Engine blown doogie48084 General PT Cruiser Discussions 5 01 Jun 2011 11:36 am
2002 2.4 engine bad matt82 Tech & Performance Forum 3 03 May 2011 08:57 am
2002 need engine 2.4 jakiept General PT Cruiser Discussions 0 24 Sep 2010 02:23 pm
substitute for 2002 engine cybilee Tech & Performance Forum 5 11 Jul 2010 06:04 am
2002 Engine Shutoff? j_desan General PT Cruiser Discussions 5 25 Mar 2010 08:07 am
