Hazards and Turn signals out.
Old 26 Nov 2011, 02:42 pm
Default Hazards and Turn signals out.
Hey there,
I took my car to get its oil changed and they told me the back turn signals were out. So I went to go get new bulbs, but I had my husband check them first. Looked good. Then we realized the front blinkers arent working and the hazards arent working either.
I have looked at the fuse box, with the guide to everything and can not find the right fuse, or relay. Anyone know where to find this? I dont have a hidden one under my dash like every other car I've had. Sometimes fixing stuff on this car just gets on my nerves.
Old 26 Nov 2011, 03:23 pm
Default Re: Hazards and Turn signals out.
Everything is different between the 01-05 and 06+ cruisers. You have to tell us what you have to get an answer.
OK, looked at your posted pictures. You have the second generation.
You might just have a burnt out flasher unit. Located, and attached to the MFS (Multifuction Switch) on the steering column.
Looking through the fuse and relay list, there doesn't seem to be a separate fuse or relay in the IPM (fuse box) for your model.
Old 29 Dec 2011, 05:15 pm
So I have just been using hand signals recently, but I am about to try these instructions I found on a website from my local library. I figured I would share them since they are more specific to a 2006 than anything else I have seen.
The website was : EBSCOhost - world’s foremost premium research database service although I am not sure if it works without a library card.
and this is a description of what the multi-function switch does
*edited post to make pictures show.*
Old 29 Dec 2011, 05:20 pm
Wants me to log on, so probably need an account.
Old 29 Dec 2011, 05:23 pm
Thats what I figured would happen. Thats why I took the time to copy, edit, and post what I found, so hopefully it may help others.
PT turn signals (or lack of) dgranros Tech & Performance Forum 6 05 Jan 2015 01:54 pm
INDICATORS TURN SIGNALS HAZARDS PATGAS Tech & Performance Forum 9 29 Oct 2013 04:59 pm
turn signals AlexJB Exterior Accessories Forum 6 12 May 2008 08:12 pm
Help with Stealth turn signals toplessPT Exterior Accessories Forum 4 16 Mar 2005 10:43 am
