Spark only on 1 and 4
Old 26 Nov 2011, 07:54 pm
Default Spark only on 1 and 4
So, I have recenltly replaced timing belt, with a great deal of trouble I might add, now I only have spark on cylinders 1 and 4. Just had the PCM rebuilt in Texas. Can the crankshaft sensor or the camshaft sensor cause this? I have checked the wires to the coil and have spark to one side only, continuity on the wires is fine. Thanks in advance
Old 26 Nov 2011, 08:48 pm
UptownSport's Avatar
Default Re: Spark only on 1 and 4
Interesting, who rebuilds PCM's?
IF belt timing is correct, I'd guess one of the PCM's IGBT's is fried.
Swap out with a local buddy's PCM or get a junkyard one.
'new' is new, and good is good.
Old 26 Nov 2011, 09:17 pm
Ratdaddy's Avatar
Did you check the coil??? How old are the wires. Just because you get continuity on the wires does not meen they have proper voltage could be a dead spark short in the wires grounding to the block...Or some sort of build up on the wire cups at the coil..Or a bad sensor.
Old 26 Nov 2011, 09:18 pm
Go.ECM in Grand Prarie Texas Guaranteed for a year. Are you thinking its not possible to rebuild? Please don't tell me that I just spent 300 buck to have it rebuilt.
Old 26 Nov 2011, 09:31 pm
I have power to the coil and have ground interruption for 1 and 4, no intrruption for 2 and 3, so I have to assume the problem is before the coil. In answer to your question yes I have checked the coil. I think it has to be one of three things, the cam sensor, the crank sensor, or worse yet the PCM that I just had rebuilt.
Old 26 Nov 2011, 09:35 pm
Also the spark plug wires and spark plugs are new. The wires I was referring to are the wires from the PCM to the coil.
Old 27 Nov 2011, 12:19 am
How do you know it has ground interruption?
Why did you have PCM rebuilt?
If coil's firing in any manner, it has power.
You could replace cam sensor- Wouldn't hurt any thing
Old 27 Nov 2011, 01:17 am
Ok, so there's three terminals that lead to the coil, the center one is power while cranking the other two are for each side of the coil, when cranking the PCM grounds either plugs 1 and 4 or 2 and 3 to create spark. If I'm connected to the pos side of the battery and the 1 and 4 side of the lead with a test light and crank it I have spark, if I do the same thing on 2 and 3 no spark.
Old 27 Nov 2011, 01:37 am
Had the PCM rebuilt because I had no spark, and had the p0601 code. I was told that while most Chrysler products would run with the code that eventually on the pt and neon it will lose spark and die. So to be on the safe side had it rebuilt.
Old 27 Nov 2011, 02:18 pm
Wow. You've got it down.
Check continuity on suspect circuit, ifgood, replace PCM
No spark, turns over but no spark? magic1021 Tech & Performance Forum 26 15 Sep 2009 07:50 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
RE: Spark Gap kennybopaloo General PT Cruiser Discussions 13 04 Apr 2006 04:24 pm
Spark Gap kennybopaloo General Turbo Discussions 13 31 Mar 2006 05:09 pm
Spark gap, .50 or .45? clevelandmike Tech & Performance Forum 6 19 Oct 2004 04:08 pm
