Oil in Spark Plug Well
Old 26 Nov 2011, 10:18 pm
Send a message via Yahoo to TulsaPT
Default Oil in Spark Plug Well
Hello guys. I have a 2004 PTCruiser, standard engine. I'm not auto savvy at all. Anyway, I went to change my spark plugs tonight. I got the intake manifold off and out of the way and pulled out the plug caps. When I pulled up the one closest to the oil cap, I noticed it had oil in it. The other three were clean and dry.
My question is a few parts.
1. What do you think the cause of the oil in the well could be?
2. How do I clean the well out so that when I put new plugs in, it doesn't foul up the new plug?
3. If there are any parts I might need, could you tell me what they are and maybe refer me to a resource to show me how to replace them?
I appreciate any knowledge that anybody can pass along.
Old 26 Nov 2011, 10:21 pm
Default Re: Oil in Spark Plug Well
Sometimes you get oil from the valve cover gasket and grommets. New gasket kit sells for $25 and are pretty easy to change
Old 26 Nov 2011, 11:21 pm
cruserdad1976's Avatar
sometimes you get it from filling the oil and spilling some its not a big deal pull plug let oil drain into the cylender and the crank the engin over it might start but it wont hurt anything as long as everything is clear
Old 27 Nov 2011, 12:13 am
UptownSport's Avatar
Sounds about right
Old 27 Nov 2011, 02:49 am
Hopefully, he knows who has put oil in his car and whether or not there was a spill. My vote's on the seals for the spark plug wells. Easy enough for a shade tree mech. Esay enough if you can read and follow instructions, too. Be sure to put the sealant in all the right places on the head for the valve cover gasket.
Old 27 Nov 2011, 07:22 pm
mdfrodolives's Avatar
How much oil are you talking about? Just a little? Or was the spark plug tube filled up a bit. How much of the spark plug boot was showing oil?
If it was a decent amount, you're going to have to pull the valve cover and replace the spark plug seals in the cover. You might get a Hayne's manual that will show you exactly how to do this.
Tim
Spark plug gap. AJ2005 General Turbo Discussions 7 15 Jun 2012 01:50 pm
Spark Plug Gap NavyCruiser Tech & Performance Forum 10 18 Jun 2011 09:27 pm
need spark plug help please edj8 Tech & Performance Forum 42 25 Aug 2010 12:47 pm
Oil in the spark plug 02PurplePT Tech & Performance Forum 4 10 Jul 2010 05:05 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
