2006 Auto Tranny Issue! Please Help!!
Old 27 Nov 2011, 02:54 pm
Default 2006 Auto Tranny Issue! Please Help!!
Came across this forum site today looking for possible solutions or problems with my cruiser. I have a 2006 Touring Edition Cruiser Automatic Tranny with just now 80,000 miles on it. I am having an issue with the check engine light on and the car won't shift out of first gear. Transmission fluid levels are normal with no burnt smell or color. It does,however, also have an issue with the driver side airbag light also being on without having been in an accident. I love my cruiser and am looking for any help or suggestions. It's my only source of transportation and I really need it to work right.
PLEASE HELP!!
Old 27 Nov 2011, 04:38 pm
Default Re: 2006 Auto Tranny Issue! Please Help!!
norm, welcome to the forum.
If the check engine light is on, it mean a sensor has detected a problem and sent a message to the computer to set a fault code. You need to look up that code and tell us what it is so we can help. Follow these instructions and let us know what code you have.
How to retrieve fault codes.
Sometimes though, with the transaxle, it throws a code such as P0700 which is just a generic code for a tranny problem and it means you need to find someone with a OBDII scanner to try and dig deeper and pinpoint the exact cause.
Old 27 Nov 2011, 07:18 pm
i'm going through the same identical problem with my 06. Check out my post in the General Discussion Forum, entitled "Catastrophic Electrical Failure". It should still be near the top of the list of posts.
Old 27 Nov 2011, 08:03 pm
Thanks for the advice,but I have been trying for the past 20 minutes to get the codes to display and it acts like it wants to with giving me the odometer as dashes but then it just kicks over to numbers. Never even displays done on it. Am I doing something wrong? Does it make a difference that it's an '06 with the digital compass and temp. gauge?
Old 27 Nov 2011, 08:16 pm
Yes. Somehow I think your trying to do the dash troubleshoot thing instead of looking for the code. Are you holding in the trip reset button and turning on the key? That sets up a system of checks for the dials. Don't touch the reset button. Just turn the key three times (within 5 seconds) towards the windshield without starting the engine. On the 3rd turn leave the key pointing towards the front.
Old 27 Nov 2011, 08:25 pm
Ok, got it this time but it reads done so it doesn't have any codes stored in the computer. I already had plans on taking it to my closest mechanic to have them pull the codes but I am a little worried about having to drive it a little ways from my house while it won't shift out of first.
Old 27 Nov 2011, 08:30 pm
OK, first you don't have to take it anyplace to read the codes because apparently there aren't any.
Second. Right now do a Google search with this criteria .......(without the ")
"pt cruiser won't shift out of first gear"
What you will get is a dozen or so threads with people having the same problem. Read through them and see if you can find an answer.
xwing777's Avatar
One thing to try is reset the cars computer. Remove battery cable, then press the brake pedal to remove any remaining power.
After 15minutes, hook up the battery cable then take a test run to see if anything changed.
Old 27 Nov 2011, 08:45 pm
Upon some further inspection I did find this...(see picture)
Clearly this is not a good thing. Could the battery be the problem?
Old 27 Nov 2011, 08:51 pm
Probably one of the worst looking examples of corrosion that I've ever seen. But I don't know if that would cause a tranny problem.
Dad with Question on auto tranny Hvymtl Tech & Performance Forum 3 24 Aug 2011 09:28 pm
Help: Auto Tranny Key Release Graveone Tech & Performance Forum 10 29 Jul 2011 12:53 am
Auto Tranny question!!! buo123 Tech & Performance Forum 5 18 Sep 2009 09:32 am
auto stick tranny gone QStrike Turbo Performance 2 13 Feb 2009 11:31 am
Auto Tranny Maintenance SteelBlueGT General Turbo Discussions 3 28 Oct 2004 05:40 pm
