Crankshaft sensor replacement on an 06
Old 29 Nov 2011, 03:29 pm
Default Crankshaft sensor replacement on an 06
Hi there,
I have been reading these forums for quite awhile and been able to do a lot of my own repairs by reading past posts. I have searched the internet as well as this site and have seen others with my issues with finding the crankshaft sensor, but I cant find it for the life of me. The pictures online are horrible. From what I can tell, it may be near the starter, but I am not even sure where that is. I was hoping someone could explain, possibly with pictures, where the crankshaft sensor is. I.E., would I access it from the top or the bottom, and whether it is closer to the rear firewall or the front of the engine. I have a 2006 non turbo pt cruiser.
Thanks for any help..
Ben
Old 29 Nov 2011, 03:37 pm
Default Re: Crankshaft sensor replacement on an 06
Ben,
If you stand in front of the car and look down behind the radiator in the front, your see the starter, behind that is the sensor.
Old 29 Nov 2011, 03:43 pm
Thank you. Of all the amazing information on google, that was the most straight forward explanation of where to find it I have received. I now have the general area to work from. I still don't see it with all the wires right there, should it be pretty obvious, or do I need to remove anything to get to it. I'm sure I am looking right at it so I am going to keep looking.
Old 29 Nov 2011, 04:22 pm
Here's some more to read:
Crankshaft Sensor on 2007 Cruiser (remove starter?)
Crankshaft Position Sensor location 04 PT Cruiser - FixYa
crankshaft position sensor ab33arch Tech & Performance Forum 23 31 Mar 2017 04:13 pm
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
crankshaft sensor stuck kowalski4 Tech & Performance Forum 6 20 Nov 2011 12:13 am
Where is the crankshaft sensor? barry8108 Tech & Performance Forum 2 08 Dec 2010 06:24 pm
HELP! Crankshaft pos sensor won't come out! reluctantlycrouched Tech & Performance Forum 0 09 Jul 2010 08:33 pm
