Adjustment screw or waste of time ?
Old 01 Dec 2011, 05:27 pm
HouRaymond's Avatar
Default Adjustment screw or waste of time ?
I'd been reading all the posts about how the PCM controls the idle. Well, being a semi-believer, I went looking on my '06 and found that there is a 'security torx' screw that would appear to be able to adjust the throttle plate 'home' position. Unfortunately, not having the right torx bit, I couldn't try, but would I be correct in the assumption that if I give that a turn, and force the throttle plate to be open a hair more at home position, wouldn't that increase my idle ? Or will the PCM take over and simply reduce the fuel flow ?
Reason I ask is, it seems to like idling at @ 600, making it a bit rough ( something to do with the balancer thingy that is supposed to help smooth it ).
If I hold the pedal, and ease it up to around 750-800, it feels MUCH smoother.
Figured it's at least worth the ask, before I go spend a few bucks on torx bits.
Any ideas ?
Old 01 Dec 2011, 08:32 pm
UptownSport's Avatar
Default Re: Adjustment screw or waste of time ?
Originally Posted by HouRaymond View Post
if I give that a turn, and force the throttle plate to be open a hair more at home position, the PCM take over and simply reduce the air flow
You are correct
Old 02 Dec 2011, 12:13 pm
HouRaymond's Avatar
Well, shucks. Guess it was worth a try....
Old 02 Dec 2011, 12:57 pm
IDK what these are supposed to idle at-
Mounts may be shot (prolly, if you haven't replaced them in last month )
The PCM will also drop idle to 500 RPM IF it believes car is overheating.
CTS was different than gauge sensor in Neon- Can think now how PT sensor is setup
IOW, sensor could be giving PCM inaccurate info
What are other's PT idling at???
Old 03 Dec 2011, 10:30 pm
HouRaymond's Avatar
Doubt if it's any of those. Just bought it from dealership that gives all cars 125 point inspection, and trust me, when they say it passes their standards, they mean it. Drove it all day today with A/C on, and it did idle about 750, and was real smooth. Maybe it's just my imagination that it's low, maybe it's right where it should be for a stick. I've just finished a tank with some injector cleaner, and it is starting to get smoother. Filled up and added another round of cleaner today, so I'll see what that does for it. Hard to say. I may still get a set of security Torx and give it a turn. Arg, I do have to wait till the next few days of rain and cold pass by.
But, thanks for the suggestions.
Need Dash Tweeters Measured Screw to Screw- MoparHemiPower Sound and Security Forum 3 13 Sep 2011 06:41 pm
Waste gate mod PETEY_CRUISER Turbo Performance 11 07 Apr 2011 12:42 pm
where is waste gate solenoid PATGAS General Turbo Discussions 1 20 Jun 2010 07:54 am
Waste Gate Replacement ? LAF Turbo Performance 7 15 Jun 2004 01:33 pm
K&N drop in a waste of time? Blue Streak Turbo Performance 8 09 Mar 2004 03:41 pm
