Lights Dim Momentarily
Old 02 Dec 2011, 04:51 pm
My02RedRide's Avatar
Default Lights Dim Momentarily
2002 recently bought. Notice with night driving and engine idleing and headlights the headlights will dim for a moment when the rad fan comes on. This normal or is this the sign of something bigger. Battery cables are clean but not sure down at alternator.
Old 03 Dec 2011, 11:29 am
Default Re: Lights Dim Momentarily
Same thing used to happen with my 08 PT until getting around to replacing the puny stock battery cables with larger guage (#4awg copper) and using better terminals. Also removed the ridiculous sheet metal screw ground on the left inner fender and replaced it with a bolt and bonded all the ground points together with #10awg copper...now the dimming issue is barely noticeable if at all plus much better electrical performance including stronger starter cranking.
Old 03 Dec 2011, 12:37 pm
No it's not mormal. Agree with Carl. Have the battery and whole charging system checked out. Most decent auto stores will do it for free. Check and clean all the cables connected to the battery and check the grounding.
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Smoked tail lights and reverse lights! chris15 Exterior Accessories Forum 15 01 Jun 2010 05:53 pm
Need a poll answered: Should I tint all my lights or buy euro/projector lights? 85_305 Exterior Accessories Forum 2 17 Jun 2009 08:38 pm
