Removed the head...did not find a bad gasket...???
Old 05 Dec 2011, 10:52 pm
wheelgarage's Avatar
Default Removed the head...did not find a bad gasket...???
But, when removing the head bolts, no.7 didn't seem as tight as the others. This was the cylinder that kept throwing the code. The gasket did look good, did not see any cracks????
It did looks like there was water getting into this area from just the extra space in the sandwich.
Going to send the head out to check for any cracks or warping. I do hope it turns out good.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 06 Dec 2011, 12:50 am
Default Re: Removed the head...did not find a bad gasket...???
Got some dinner and looked at the gasket again.
I did noticed that the composite layer is gone, top right, between the cylinder and the water jacket.
I do see some carbon flakes on the out perimeter of the pistons. Going to clean as much out as possible.
Old 06 Dec 2011, 07:28 am
I'm not an internal engine expert but that does look like that was your problem.
Old 06 Dec 2011, 10:34 am
It actually was the problem.
I did measure out the thickness through out the gasket, and yup...composite layer gonzo. I am really surprised that the gasket only lasted 100k! These types of issues always happen when two different materials are used, aluminum and iron!
I plan on reducing the amount of HOAT and increase water into mix....80% water/20% HOAT. Also, going to add Redline Water Wetter, which will reduce electrolysis. Lesson learned.
At the time I pulled the head, I isassembled the exhaust manifold and broke off one of the heat shield bolts....which piss'd me off...it was soaked in PB! Oh well, easy fix anyway.
Head Gasket Fix? Tn_Hogger Tech & Performance Forum 9 25 Aug 2011 12:10 pm
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
head gasket broadleaspeaking1 General PT Cruiser Discussions 1 27 Mar 2008 05:44 am
Head Gasket Kirby Stage Turbo Kits 7 04 Nov 2003 10:59 pm
