PT Cruiser Forum Car Videos
Custom Wheels
Spark Plugs
Old 18 Jan 2004, 10:43 pm
mcruz mcruz is offline
Default Spark Plugs
Anyone tried iridium spark plugs and coresponding wires offered on sparkplugs.com?
I would be willing to pony up the bucks if I thought it would help performance and gas milage.
Old 18 Jan 2004, 11:07 pm
CREWZIN CREWZIN is offline
Don't know about performance but new plugs have helped a few of us with rough idle and off the line lag. Here's a write-up from another forum:
http://ptcw.truckmoxie.com/TenArticle.asp?aid=348&sid=8
Old 18 Jan 2004, 11:39 pm
Thanks CREWZIN, I think I will give them a try in the spring when it is warm enough to spend the time as it looks like an involved process.
Marty from MD
Black GT 03, BTG cat/back duals, rocket taillights, BTG shock strut bar, & Blane hood struts
Old 19 Jan 2004, 12:46 am
Sci-Fi Sci-Fi is offline
Personally I would wait. Denso is supposely redesigning the spark plugs to be dimensionally/physically correct. That means no need for a special socket or special spark plug wires. It has been mentioned before that if you lose/misplace or even break the special spark plug socket or need to replace one or more of those special length SP wires, you are pretty much out of luck. If you read that article, they left the gap at 0.040, not regapping them to the OEM specification of 0.050. So naturally it would seem to run better. You could gap any other plugs or even your present plugs at 0.040 and get the same results they got.
Old 19 Jan 2004, 12:56 am
bobs turbo pt bobs turbo pt is offline
how much of a pain in the ass is it to change the plugs??
Old 19 Jan 2004, 01:21 am
skeeter1620 skeeter1620 is offline
there was another forum on ngk plugs that are new , cant remember the part number on them
2003 Dream cruiser 2 #1434
mopar bov and k&n drop in filter ,billet shorty antenna, silencers removed, custom painted rear shelf that says\"Dream Cruiser II\"and maybe, doubtfully soon------stage 1
Old 19 Jan 2004, 04:05 am
This is the problem with Denso's (courtesy from bstockum):
Old 19 Jan 2004, 11:04 am
IRPT IRPT is offline
More info here...
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=5633
http://www.ptcruiserlinks.com/forum/...,spark, plugs,
http://www.ptcruiserlinks.com/forum/...,spark,p lugs,
2002 Inferno Red PT Limited
Mercedes Wiki
Old 25 Jan 2004, 12:13 am
After reviewing the comments here I think I will wait and see if they come out a plug that fits better.
Marty from MD
Old 25 Jan 2004, 12:23 am
Not as bad as the "back three" on a transverse V-6, but the worst 4 I've ever done.
Go to PTDoItYourself.Net and see - I used the "shortcut method", propping things up with a wooden stick to save disconnecting more stuff.
I would suggest doing wires at the same time - the stock wires gave me a miss, so I did Crane wires (Race and Street), (had already done the platinum plugs) heaven't missed a beat in 30-40,000 miles (have 70,000 + miles on my PT now).
Your money, but why go with plugs "jury-rigged" to fit, when there's the Champion platinums?
Few more tips - check the gaps before you put the new plugs in - mine were off quite a bit "out of the box".
Get "anti-seize" and put it on the plug threads. Get "dielectric grease" and put it on inside & outside of plug wire boots to keep moisture out and keep boots from sticking to engine and plugs.
vB code is On
E3 Spark Plugs CREWZIN Tech & Performance Forum 6 11 Dec 2004 01:03 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
spark plugs ote69 Turbo Performance 24 12 Oct 2004 01:44 pm
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
  Problem Mortgage | Mortgages | Credit Cards | Personal Loans | MPAA
