Funky acting tranny
Old 07 Dec 2011, 06:45 pm
Default Funky acting tranny
Got a2001 cruzer auto tranmission the problem is you put it in drive won,t go if you bring the r.p.m,s up 4or5hundred above idle it wil take and go thru the gears like it should and as long as you leave it in drive it works great if you stop and put it in park or nuetral it will act up again reverse no problem works just fine it,s only the forward gears checked fluid level full any ideas? I was thinking maybe the filter is plugged but it's funny it only does it in forward and not reverse.
Old 07 Dec 2011, 06:49 pm
cruserdad1976's Avatar
Default Re: Funky acting tranny
have you had the fluid changer??? how many miles
Old 07 Dec 2011, 07:43 pm
Not sure it's my daughter inlaws car but I have to do the work on it. I think there's around 120,000 on it she bought it used so I don't know when or if it's been changed the fluid looks good
Old 07 Dec 2011, 08:11 pm
New info it's a2002 not an 01 it has 90,000 miles on it the tranny fluid & filter was supposedly changed @ 70,000 the problem with that is I know the dealer she bought it from and he is shall we say a little shady so assuming he did change it it's only been 20,000
Old 07 Dec 2011, 09:11 pm
well a dealer should knwo that it HAS to be ATF+4 id say start with a fluid and filter change it cant hurt see what happens from there--if you open up the tranny and it smells burnt you will ahve a clue
PT is acting weird when A/C is on the_jeep_now Tech & Performance Forum 13 22 Aug 2011 09:42 am
Sunroof acting weird Franksredpt General PT Cruiser Discussions 2 10 Apr 2009 11:12 pm
So my Trans MIGHT be acting up? Cathy06PT Tech & Performance Forum 6 11 Nov 2008 10:57 am
Dash acting weird Nikkortim General PT Cruiser Discussions 8 04 Sep 2005 06:30 pm
My PT is acting up at 68K miles (VERY BAD) Ctown General PT Cruiser Discussions 2 11 Mar 2005 11:10 am
