PCM/ECU Location
Old 09 Dec 2011, 08:44 pm
dsmturbo's Avatar
Send a message via MSN to dsmturbo Send a message via Skype™ to dsmturbo
Default PCM/ECU Location
I should know this but where is the PCM/ECU located on a 2003 Turbo?
Is it passenger's side inside firewall under glovebox or ?
Old 09 Dec 2011, 08:49 pm
Soulman's Avatar
Default Re: PCM/ECU Location
It's under the hood against the firewall next to the master cylinder if you have auto trany there will be 4 plugs if standard 3 plugs
2003 GT Turbo HO,Autostick,Stone White,Stage 1 ECM,Composite Intake,BTG Strut Brace,2004 GT Race pedals,Mopar BOV,VMS 10.2mm spark plug wires,NGK Copper plugs,K&N Drop In Filter,Air Box Mod,Gates Hi-Miler Upper & Lower Blue Radiator Hoses,Gates HP Blue Timing Belt,Clark & Clark Hood Struts color matched to car,PTeazer LED Teardrop Tail Lamps,245/45ZR17 Continental Extreme Contact DWS,Blue Tokiko struts and shocks,Eibach lowering coils front & rear ,Eibach sway bars front & rear,New Moog Lower Control Arms,Hyperflex Master Bushing Kit,Moog Strut Mounts,MB Motorsports Alpina 17x7.5,Mopar sub,AMI billet locking fuel door,2005 GT Stainles BrakeGas and foot Rest peddles,PTeazer Billet Door Sills,Billet emergency handle,EGR rain guards,Air horn,9" shorty billet antenna & a splash of bling
Old 09 Dec 2011, 11:11 pm
dsmturbo's Avatar
Thank you, I did not realize it was under hood, and yes Stage 1 for replacement is a 4 plug.
Turbo location? tdzachar Tech & Performance Forum 2 21 May 2011 04:42 pm
Location of the thermometer? ProDigit General PT Cruiser Discussions 8 13 Dec 2010 08:17 pm
PCV location discovering06 Tech & Performance Forum 9 22 Jul 2010 01:12 pm
Hello and Please help with Fuse location DelValPC Tech & Performance Forum 2 01 Jul 2008 02:28 pm
Tee Location Mean Green Turbo Performance 6 07 Jan 2004 01:41 am
