My PT Cruiser WON'T start (flashing red dot)
Old 11 Dec 2011, 06:43 pm
Default My PT Cruiser WON'T start (flashing red dot)
I have a 07 pt cruiser 2.4. It has not started since Thursday. I got myself stuck on a curb and had to be pulled off. When I tried to start my car to go, it was dead. Lights, radio and doors all worked just won't kick over to start. I changed the battery because it was weak and tried to pull all the fuses and checked them. My security light on dash keeps blinking red ... from what I have read it has to do with the security system shutting down. I am in a serious situation.. HELP!
Old 11 Dec 2011, 11:58 pm
Default Re: My PT Cruiser WON'T start (flashing red dot)
CAN ANYONE TELL ME HOW TO FIX THIS SECURITY PROBLEM????
Old 12 Dec 2011, 12:27 am
WolfmanG's Avatar
you better watch your tone newbie, when you write in all cap's that means your yelling. If some one can help they'll step up, till then you can you might want to ask the guys at PTcrew.com. or take it to the dealership or look around for a mechanic.
-Danny Wolfman G
Old 12 Dec 2011, 06:41 am
Thanks ... calling around for mechanics and dealerships today... so frustrated... sorry... around this time of the year, I really can't spare the extra cash to get something fixed, I was hoping someone knew how to fix it.
Old 12 Dec 2011, 02:50 pm
Try opening the rear hatch with the chipped key. This is the method to disarm the factory alarm on several Chrysler makes, though I'm not sure if it applies to the PT. I assume you are using the chipped key (if yours has one) for your starting attempts. If that fails, and you have not already done so, use the fob to lock and then unlock all the doors, then use the chipped key to do the same.
So many people come here with an issue, then move on and don't let us know if they resolved it (and how.) Please let us know, okay?
Old 12 Dec 2011, 07:04 pm
Well we didn't try the hatch because my key don't open it. I hand open it. I did try to take out all fuses, replacing them, replacing the battery itself, and all the other thing we found on the internet. I had it send to a Chrysler dealership and they called me with the news. There are 4 plugs on your PCM... well one of my wiring connectors have to be replaced. Who ever had worked on my car messing with these items was really rough with it and shoved it back together which bent the prongs on the computer. Good news is that the prongs were able to be bent back into place.. but the connector has to be replaced. I'm having a heck of a time finding the part at a bone yard so I might have to order it from Chrysler which is going to cost 100.00 bucks. I hope this helps someone else in the same situation!
Old 12 Dec 2011, 07:42 pm
There's almost no way this will help someone else unless they too had someone that didn't know what they were doing mess around with the computer hook-ups. That was something you forgot to tell us, that you had work done involving the computer which has a lot to do with the security system.
Old 13 Dec 2011, 08:02 am
....Good news is that the prongs were able to be bent back into place.. but the connector has to be replaced. I'm having a heck of a time finding the part at a bone yard so I might have to order it from Chrysler which is going to cost 100.00 bucks. I hope this helps someone else in the same situation!
Thanks for letting us know... good luck!
Old 04 Jan 2012, 02:02 pm
I searched here with exactly this problem. My 01 has had the same issue in the past, but was fixed with the Fob, which I have since lost. The key opening the rear hatch worked!! thank you so much for the advice. I was starting to trip out...
Old 21 Jan 2012, 01:30 pm
Well I guess It helped someone after all! Although indirectly. It's really not hard to find someone to work on your car that doesn't know what there doing. The dealerships are full of them. On average, only 10% of techs. are really really good and they are busy fixing the mess-ups of the lower end of the scale techs. So usually you will get one of the middle range guys (if your lucky) or the bad ones that keep the top 10% busy with there come backs.
04 cruiser won't start!! HELP PLEASE!! sconnors11 General PT Cruiser Discussions 15 03 Jun 2014 06:37 am
09 PT cruiser no start no sparks tchevelle Tech & Performance Forum 8 30 Aug 2011 02:05 pm
PT Cruiser will not start Bone Tech & Performance Forum 12 10 Jul 2011 09:04 pm
Cruiser won't start veracruise Tech & Performance Forum 5 18 Jun 2011 12:24 am
04 Cruiser ran out of gas, now will not start? Leannaluv General PT Cruiser Discussions 2 11 Nov 2010 11:07 pm
