window drop not working on my convertible
Old 13 Dec 2011, 08:06 pm
Default window drop not working on my convertible
My window will not drop down on my convertible any ideas? I did reset the pcm but still nothing took door apart and all wires are still intact
Old 07 Nov 2013, 10:08 am
Default Re: window drop not working on my convertible
What did you do to resolve this? I am having the same problem
Old 07 Nov 2013, 10:25 am
Handy_Cruiser's Avatar
If it is the driver side window, then it's likely either just the switch or the window lift motor. On most cars it's always the lift motor. And it's almost always the driver's window that goes bad first because it gets a lot more use than the others.
But I've found on my first gen. PT, that the contact points in the window switch are just as likely to be bad. And it's worth it to try and clean those first. I figure there's something about how to do it in the "How To" section.
If it is the driver's window, go ahead and buy a new or rebuilt lift motor. A used one will likely to just go out too after a while because the driver's window gets so much use.
Old 07 Nov 2013, 12:35 pm
The window drop feature is called smart window, and there is a module that controls it. Usually if you disconnect the battery for five minutes it will reset. There is a fairly length discussion on the convertible forum here called window problem. It is about six pages back from the new threads. I would read it first.
Old 07 Nov 2013, 11:25 pm
to reset the module, you must have both doors open when you disconnect the battery
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
Rear window defroster not working ukbeachbum General PT Cruiser Discussions 8 16 Nov 2011 09:56 am
Drivers side window and cigarette lighter not working? TurboPTChick General PT Cruiser Discussions 5 23 Jul 2010 08:03 pm
Passenger Window Keeps Sliding Down - Auto Up/Down Not Working lornadobson General PT Cruiser Discussions 5 01 Mar 2010 07:36 pm
2005 PT GT Convertible Window gbopper PT Cruiser Convertible Forum 3 29 Nov 2008 12:13 am
Back power window switches not working lumofny Tech & Performance Forum 3 16 Jan 2005 10:00 pm
