New timing belt sliding off pulley
Old 14 Dec 2011, 04:16 pm
Default New timing belt sliding off pulley
So....this is PT #4 for me (LOVE EM). Ordered the car special in 2005 and have been its only driver since 2 miles on the odo. Impeccable care has been taken including all service intervals and normal wear and tear. Had to drop a new clutch in at 50k and am now at 70k.
While riding down the highway on Friday of last week the car went dead and I pressed the clutch and pulled over immediately. Wouldn't start so I had it towed home (I own a wrecker company thankfully lol!).
I read a few things and checked out the cam sprockets through the hole on the timing cover to see that when turned over, they didn't spin. Timing belt is off.
Pulled it in the shop and started tearing it down only to discover that Chrysler design gurus should all be shot. Immediately. WOW what a hassle!
Bought timing belt, water pump, timing idler and tensioner. Removed old stuff (belt lost teeth in two spots) and started replacing the components as the shop manual instructs. Timing lined up right and so forth but here's the problem.
When we assembled the timing configuration and rotated the motor 2 full rotations to test if the timing marks were right (they are) the belt is working it's way of the pulleys toward the outside of the engine. It's most noticeable around the tensioner pulley. Being pretty sure about the components being installed properly, has anyone heard of anything like this happening? I've read a few posts about this but non of them had a solution. The crankshaft balancer was removed with the proper tools and there is no play in it.
This is really tearing at me because it really shouldn't be doing this. Tensioner is lined up with the spring tang (GREAT NAME) as it should be and is shown in the illustration.
End of my rope is an understatement....any help is greatly appreciated!
2005 PT Cruiser Conv
black on black on black....and NOT stock.
Old 15 Dec 2011, 12:49 pm
UptownSport's Avatar
Default Re: New timing belt sliding off pulley
LOL.
I felt the same way!
There one or two other recent threads with same issue, look down formu a bit, If I come across it I'll post a link.
Pulley/Belt squeak StealthyK Tech & Performance Forum 3 15 Jul 2011 09:48 pm
squeak coming from eng or belt or pulley? golf55555 General PT Cruiser Discussions 16 03 May 2011 02:44 pm
Serpentine Belt Pulley Alignment marty Tech & Performance Forum 2 28 Dec 2008 08:11 am
