rough chugging bouncing under 1000 RPM
Old 17 Dec 2011, 01:26 pm
Default rough chugging bouncing under 1000 RPM
2001 manual PT feels like it's misfiring or something. kind of "bouncy" when idling. took it to the mechanic, he said ERROR CODE P0601. then he said the part was recalled and Chrysler dealer will replace and that's the only problem with the car.
doesn't sound right to me, anyone?
Old 17 Dec 2011, 01:47 pm
Default Re: rough chugging bouncing under 1000 RPM
The code refers to a bad PCM which in some cases is covered under the 80,000 emissions warranty.
I don't know anything about a recall for that part.
Old 17 Dec 2011, 01:55 pm
thanks Crewzin'
i'm at about 93K
looks like this could cost $800
does the rough idle come from the bad PCM?
Old 17 Dec 2011, 02:06 pm
Don't think I've ever heard of the PCM causing a rough idle but that doesn't mean it couldn't happen. Lots of other things including timing being out, bad plug or wire or broken motor mount.
At 93K your timing belt could be on it's way out and that would make it mis-timed.
Old 17 Dec 2011, 02:42 pm
thanks again Crewzin'
04 PT CRUISER TURBO CHUGGING AT HIGH SPEEDS greene406 Tech & Performance Forum 2 10 Oct 2010 02:28 pm
Air Lift 1000 #60788 1lowufo Wheels, Tires, Suspension 0 25 Apr 2010 11:30 am
2001 PT Chugging at 2000 rpm jaydubbs Tech & Performance Forum 11 18 Sep 2009 02:42 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
$1000 - what would you buy? AlexJB Turbo Performance 6 19 Jun 2008 01:27 pm
