Leaky waterpump only 20k...
Old 18 Dec 2011, 01:24 am
wheelgarage's Avatar
Default Leaky waterpump only 20k...
Cylinder head on....
After buttoning up the valve cover, I began the installation of the timing belt rear cover. I noticed a dried stream of coolant on below where the pump resides. So, I took a close look at the pump. From a glance, I noticed the stream began behind the pulley, from the shaft. It looks like it has been dripping, not pouring out. I never did see any loss of coolant, leaks or residual on the the pan or on the floor.
I wish I knew to buy the OEM pump 2 years ago.....and the dealer parts are closed tomorrow....
The water pump was part of the Gates timing belt kit. The pump itself does look to be a sold piece...but. And, from recently reading post on the subject of aftermarket pumps are prone to failure, that is the truth, no doubt.
I will have pics up shortly.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 18 Dec 2011, 01:50 am
UptownSport's Avatar
Default Re: Leaky waterpump only 20k...
Gates pumps are Made in CHINA.
I bought two for $25 or whatever each, sold for $10 each
Old 18 Dec 2011, 02:05 am
The Gates one definitely isn't the business. The SRT-4 guys have very good posts about other, aftermarket, ones that have failed.
Going to call my local, family owned, parts store to see if that have a Mopar one. If not, going to call the dealer on Monday to see if they have them.
Dang, was hoping to drive the PT tomorrow....
Old 18 Dec 2011, 03:27 pm
Here are the pictures of the Gates pump....
Here are the pics of the bottom of the pulley, where the leak occurred....
Old 18 Dec 2011, 03:49 pm
Here is the Mopar pump image..
I was just looking around the local shops to find this one, from Autozone, Duralast brand, which looks to be electrogalvanizing?
Old 18 Dec 2011, 04:00 pm
Here is a Bosch one, not bad....
Old 18 Dec 2011, 04:05 pm
MasterPro from Orielly's.....looks the same as the Duralast....relabled...same MFG.
Old 18 Dec 2011, 05:24 pm
The Gates kit I put in my wife's N/A had a pump with an impeller just like the Mopar and was made in Japan...and looked very well made
Old 18 Dec 2011, 05:33 pm
Really, a reman is likely better than a NEW aftermarket pump!
The housing is exactly the same as OE, because it is OE.
I think all they do is put in a new bearing/seal cartridge, the rest of it doesn't wear.
Quality of the cartridge is the only deciding factor, unfortunately the bottom line decides the quality.
Old 18 Dec 2011, 09:49 pm
Interesting, when did you replace it? They must have cut distribution at one point...
Orielly's and Autozone do carry remanufactured ones. Should I consider really consider those? I'm thinking the new ones, that look exactly like the Mopar ones should be good....especially the ones that look to have the electorgalvinized coating....which are actually new.
2004 2.2 CRD Waterpump replacement elwell Tech & Performance Forum 2 06 Oct 2010 09:27 am
leaky rims silas2010 Tech & Performance Forum 5 18 May 2010 05:29 pm
Leaky transmission FaulknerCountyCruiser General PT Cruiser Discussions 5 12 Nov 2008 10:36 pm
Leaky Sunroof Miami_PT_Fan General PT Cruiser Discussions 7 09 Apr 2008 05:32 pm
Waterpump replaced, now problems. ptguy Tech & Performance Forum 4 07 Sep 2007 05:12 pm
