Downstream O2 sensor
Old 19 Dec 2011, 08:29 am
davea300's Avatar
Default Downstream O2 sensor
Does anyone know if there is a difference in the downstream oxygen sensors for early pt's compared to later (2005+) models. I've been looking locally for a replacement sensor but some places are telling me that 2001/02 models are different to 2003/05 models.
Also in the UK the pt had a facelift in 2006 (I think it will be the same in the US). I'm not sure if I can get a sensor for a new model and fit it to my pre facelift 2005.
Problem is some parts stores simply list "Lambda sensor - pt cruiser" and have no year against it.
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 19 Dec 2011, 10:20 am
wheelgarage's Avatar
Default Re: Downstream O2 sensor
I believe the connectors might be the only difference. Check Rockauto.com, they have good illustrations of available O2's....
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 04 Jan 2012, 08:31 am
davea300's Avatar
I got hold of a downstream o2 sensor for a 2003 PT and it fits my 05 car. So far no problems with it.
67,000 miles
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
Map Sensor. Turboguy85 Turbo Performance 15 23 Mar 2012 03:19 pm
o2 Sensor Help Shepard0317 Tech & Performance Forum 2 28 Jan 2011 08:23 am
cam sensor stillcruisin Tech & Performance Forum 3 05 Dec 2010 04:12 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
