A Proper Water Pump....Mopar
Old 22 Dec 2011, 12:18 pm
wheelgarage's Avatar
Default A Proper Water Pump....Mopar
For the sake of reference, here is a Mopar compared to a Gates (2009 version) water pump. The Mopar impeller looks to stamped steel, assembly is larger and thicker in some parts. The pulley spins smoothly and solid. The Gates impeller is cast metal. From recollection, the pulley did not spin smoothly, felt like the spring was loose, consistently moving from its seat.
In conclusion, the Gates was defective out of box. I am only assuming that the design and assembly of this unit caused the ingress of the head gasket failure.
Pictures to follow...
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 22 Dec 2011, 12:27 pm
Default Re: A Proper Water Pump....Mopar
Old 22 Dec 2011, 12:29 pm
Mopar:
Gates:
Old 22 Dec 2011, 02:24 pm
UptownSport's Avatar
Did it look like this?????
20 or 30k on it ...
Old 22 Dec 2011, 04:41 pm
That's serious!!!....probably would have been if it stayed in there longer....
Old 22 Dec 2011, 06:53 pm
xwing777's Avatar
Their is also plastic blade version for turbos. Higher flow rates for extra cooling.
Old 22 Dec 2011, 08:54 pm
harrym's Avatar
Thanks for posting this! Those pictures show the difference clearly!
Water Pump Backordered compdr59 General Turbo Discussions 14 31 Oct 2011 02:31 pm
change water pump mweems14 General PT Cruiser Discussions 2 10 Jul 2011 07:43 pm
water pump replacement johnnyx Tech & Performance Forum 10 15 Jun 2011 11:20 pm
Water Pump rute66pt General PT Cruiser Discussions 4 03 Dec 2009 01:56 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
