Repairs, Codes, and Budget planning
Old 24 Dec 2011, 04:59 am
Default Repairs, Codes, and Budget planning
I know this is probably an intake gasket issue, but I would like to be sure before I put the car in the shop again...
I have a 2004 GT Turbo with 100K miles, Check Engine light came on when the weather got a little cold here last week in the Commonwealth of Massachusetts.
Code came up as P0304 and P0551
Car was Idling like poop, and I needed brakes anyway, so off to the shop it went.
Plugs, Wires, Brakes (front) Rotors (front), Lube/Oil/Filter/fluid top-off (Power steering was a little low), and a new coil because the #4 output was actually low, and all seemed happy again, except for a slight , but noticeable lag (1-2 second) when I start to accelerate from a stop, I feel like I need to give it more gas, then it "wakes up" and I am pulling away a bit faster than I am used to.
Then it got cold here yesterday again, and P0304 came back, with the car idling like poop if I am stopped for more than 10-15 seconds, and the Check Engine light blinks at me. It runs fine once moving, but the stopped idle is very rough. I assume this may just be the intake gasket and will run back to my mechanic to get it checked out.
My couple of questions:
If the the gasket check (starter fluid, brake cleaner or similar around intake near #4, see if idles better) does not show any improvement, what should my next step be? A can of injector cleaner in the tank?
Is there any chance the P0551 was just a matter of slightly low fluid?
Also, since I am just about due for the Water Pump / Timing / Tensioner job anyway, is there anything else I should do while all this wonderful work is going on? I just had the Cam and O2 sensors replaced (Both O2 were flaky)
Best Guess on how much to budget for the overhaul?
I wish everyone a happy ChristmaChanuKwanzakah!
In-car netbook desk planning. geronimo Interior Accessories Forum 7 12 Jan 2010 09:04 pm
Planning a new system slayerdarkcross Sound and Security Forum 6 26 Apr 2009 09:04 am
Stanton Car Show Event Planning slayerdarkcross General PT Cruiser Discussions 2 10 Dec 2008 03:08 pm
REPAIRS at 65k Teekypt Turbo Wheels/Suspension/Handling 17 21 Aug 2008 11:22 pm
Chrysler CEO paid price for poor product planning skylight PT Cruiser News and Rumors 10 03 Mar 2004 11:33 pm
