Power steering leak
Old 24 Dec 2011, 12:02 pm
Default Power steering leak
A week ago. everything was fine. no problems. one day my wife said the pt was making strange sounds and PS was going in and out quickly. So i figured low on fluid. Get home. Check it. its about completely empty and absolutely no PS. So i put some in, start it up turn the wheel. and it has some PS but nothing id trust my wife to drive. I turn it off, see if i need to put some more in there, and im talking every bit of fluid i just put in, was laying on the ground... I lift it up, and see that it looks to be coming from a hose.. connected to the radiator? looks like the fitting the hose is clamped to is leaking... bad. pump is dry, reservior is dry for the most part. but its definately coming from the very front middle of the car... havent had this vehicle long.. and its kinda getting on my nerves.. any ideas? is this a simple hose replacement fix? or what. i dont mind driving it with no power steering if i have to for a while but id like to fix it.. thanks guys. this is my first post by the way. ive had this car about 3 weeks and this is the first major problem ive run into. timing and tensioner etc. usual problem parts have been replaced already so i thought id be good to go for a while... appreciate any input.
Old 24 Dec 2011, 12:11 pm
Talking Re: Power steering leak
That sounds like a leak at the power steering cooler. Check with a local radiator shop. They may have a fix.
Old 24 Dec 2011, 12:28 pm
Default Re: Power steering leak
Dang. Alright thx
Old 24 Dec 2011, 12:35 pm
OK, I found it. It's actually coming from a split hose, and shooting across and hitting radiator. The hose is about an inch thick, mesh. Metal ends. Going from rack to up near the passenger side. I can't see the other end.
Old 24 Dec 2011, 01:22 pm
That sounds like one of the recalls that the PT had for rubbing power steering lines. The line could rupture and cause a fire. I'd check a dealer to see if that recall was done on your PT and you may get a free fix. Just take you VIN number to the dealer to see if it was taken care of.
Old 25 Dec 2011, 01:50 pm
Called dealer. Recall was pperformed in 2004. Guess I'm paying for this one cuz I don't want to tackle that.
Power steering leak oliverav Tech & Performance Forum 12 07 Apr 2013 09:46 pm
Power Steering Leak (help) mjb457 Tech & Performance Forum 3 13 Jun 2011 05:46 am
Power steering high pressure hose leak. canbug Tech & Performance Forum 2 13 Mar 2011 08:16 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
