different oils
Old 25 Dec 2011, 04:38 pm
Default different oils
how many people change there oil viscosity in the winter? my parents got me 5w-20 for Christmas because that's what they thought went in. my grandfather said it would work in this cold weather since its thinner. how many people have run lower thickness for winter? i just don't want or need to screw up the engine! i'm a pt lover! not a hater.
Old 25 Dec 2011, 06:35 pm
Talking Re: different oils
Check the manual or even the oil filler cap. I believe they recommend the same oil year around.
Old 25 Dec 2011, 07:54 pm
Fuzzyweis's Avatar
Default Re: different oils
The recommended oil is 5w-30, the 5w means when it's cold(Winter) it has the viscosity of a 5 weight oil, and the viscosity of a 30 weight when it reaches operating temperature. It's science!
It also means that in the cold of winter, there's no difference between 5w-20 and 5w-30 when starting, just at operating temp, and 30 is the recommended viscosity for operating temp.
So 5w-30 is good for cold weather. The other way to go would be if it's really hot weather, like Phoenix or Dallas in the summer, you could run straight 30 weight oil (SAE 30), and it shouldn't adversely affect the engine.
-Jim
Old 25 Dec 2011, 10:11 pm
mdfrodolives's Avatar
Don't use 30w oil in your PT--no matter how hot it gets. That's for lawnmowers and old VW Bugs.
If you live in a hot climate, use 10w30w (during the hot months). Otherwise use 5w30w.
Tim
Old 25 Dec 2011, 10:47 pm
Matt42's Avatar
Tim
+1 And it gets hot here.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Any difference between synthetic oils? dolemite Tech & Performance Forum 2 25 Sep 2007 02:11 pm
synthetics or regular oils?? EASY General PT Cruiser Discussions 9 24 Jul 2007 07:02 am
When to start using Synthetic Oils Chip General Turbo Discussions 5 09 Nov 2005 10:10 am
Petroleum or Synthetic Oils Art Rigby Tech & Performance Forum 9 29 Jul 2004 09:51 pm
Synthetic vs. Petroleum Based Oils GTcamster Turbo Performance 8 18 Apr 2003 07:32 am
