battery issue
Old 27 Dec 2011, 11:36 am
Default battery issue
hii im having trouble turning on my car i change the alternator, battery and i still have to jump cables in order to turn it on.what can the trouble be?
Old 27 Dec 2011, 11:46 am
Default Re: battery issue
Apparently you either have a short somewhere or maybe bad cables (corrosion). Sounds like you just threw parts (battery/alternator) at the problem without actually knowing what the problem is except that it wouldn't start. If you would have taken the car to one of the auto stores in your neighborhood, they could have checked your battery and charging system and told you if you needed to change those parts. You could also have a drain on the battery when it sits so it wears down the battery. Do you have a meter that you can test the voltage that you have when it's running, when it's turned off and when you try to start it again?
Looking at your first 2 posts, you were having timing issues. Did you get that straightened out? Could it be that you have the timing 190 degrees off the correct setting, or maybe even a few degrees that would stop the car from starting?
Remote Unlocking Issue (battery ?) Technicolour0 General PT Cruiser Discussions 11 04 Feb 2012 10:59 am
Need advice on battery installation issue. DSJayce General Turbo Discussions 3 20 Jun 2011 04:21 pm
A/C Issue -- Help! Brick Tech & Performance Forum 12 02 Jun 2011 05:41 pm
2005 PT Cruiser Battery Issue Hillarican Tech & Performance Forum 10 29 Dec 2010 07:16 pm
