2001 pt cruiser 4 cylinder car will not idle
Old 29 Dec 2011, 10:01 am
Default 2001 pt cruiser 4 cylinder car will not idle
hello all, I have a 01 4 cylinder pt cruiser, the car can start I can rev the engine but it will not idle it will just shut off. any ideas? please help.
Old 29 Dec 2011, 11:05 am
Default Re: 2001 pt cruiser 4 cylinder car will not ideal
According to your other post it's been good for years. You give no other information so; when was the last time you changed the plugs and wires? Ever run some cleaner through the gas tank for the injectors? Have you tried anything? A little information goes a long way.
Old 29 Dec 2011, 11:12 am
hi crewzin, thanks for responding. I changed plugs and wires 6 months ago, have not ran cleaner though gas system. I changed out radiator hose a month ago. not sure what it could be.
Old 29 Dec 2011, 12:00 pm
Ok, there is something that controls the Idle called the IAC (Idle Air Controller) and it can get dirty and cause problems. It's cheap enough to buy and replace but it can also be taken off and cleaned. There's a spring inside and if dirt gets in, it can hinder the operation of the controller. it's located on the back of the throttle body and it's on my picture below with a yellow star. It only takes a little time and effort to take it off BUT it's held on by two Torx screws so you need the right tools to take it off. I use a No#20 Torx drive head on a ratchet wrench becuase it doesn't take much room and between the screw heads and firewall is only a couple inches.
Old 12 Oct 2012, 02:33 pm
Default Re: 2001 pt cruiser 4 cylinder car will not idle
^ spam bot. reminds me of the ebay turbo lister auto feedback
2001 PT Cruiser Teckspeed General PT Cruiser Discussions 10 02 Jul 2011 08:44 pm
2001 PT cruiser rim ericamao Wheels, Tires, Suspension 1 03 Dec 2010 05:47 pm
PT Cruiser 4 cylinder (non turbo) rev limit DJmart Tech & Performance Forum 8 27 Mar 2008 10:44 am
Ideal PT Trailer PTwithmyTT General PT Cruiser Discussions 0 12 Oct 2007 01:02 pm
