timing belt gear broken???
Old 31 Dec 2011, 12:08 pm
mdskinner731's Avatar
Default timing belt gear broken???
working on our new 2001 pt cruiser this morning, and i broke the timing belt gear that goes on the crank shaft it happened wen i was pulling the harmonic balancer off its not cracked but about 1/8th of an inch of the outer lip broke... whats yall's thought on reusing it?? (please note: no teeth were damaged during this process) lol! its only like $15 but its about 5 days away; and i wanna get this car done!!!
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 31 Dec 2011, 12:24 pm
Default Re: timing belt gear broken???
That's the bottom gear in the picture, right. I'm no exert, and you should wait for someone who is but if it's only part of the lip, I can't see it hurting UNLESS it affect the rotation and you could get a vibration because it's not balanced anymore.
Old 31 Dec 2011, 01:55 pm
thx crewzin! it is just the outer plastic piece!! i cant imagine it throwing the motor out of balance. after all its a very small chip missing. i'll let my pops make the decision on what to do with it. if its junk ill replace it....
but since were on the subject... how would i go about extracting it off of the crank?? i still wanna change the crank seal on this one
(after all i never changed the one on my car)
Old 31 Dec 2011, 02:04 pm
I wold think you need some sort of puller but again, expert advice hopefully will come along. In the meantime, here's a couple things I found in a search.
crankshaft pulley removel
tools needed to pull crank pulley from 2.4 motor? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
help with removing crankshaft pulley - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Old 31 Dec 2011, 03:54 pm
UptownSport's Avatar
You need to use a steering wheel puller, and three very long M6 x 1 bolts.
Coil bolts aren't long enough for most pullers. With correct puller, they come off easily.
Neon owners remove them with a chisel, and because of this procedure must replace them; There should be one in stock in NY, find it very hard to believe it couldn't be got in a day.
Please ensure you don't put it on backwards, it happens to smarter people than I.
use a super thin coating of grease. Guys can and do break them from being over-exuberant tightening them. I haven't had this problem.
I don't see balance as being the issue, that area is a guide to keep belt on front.
Old 31 Dec 2011, 04:01 pm
Thank UptownSport. Hoping someone with experience would come along.
Broken timing belt/broken valves DreamCar Tech & Performance Forum 17 13 Mar 2012 01:35 pm
Broken timing belt/whadoido JCCook Tech & Performance Forum 15 14 Sep 2011 03:36 pm
Broken timing belt mantonmark General PT Cruiser Discussions 4 12 Aug 2011 05:47 pm
No start after broken timing belt mojojo Tech & Performance Forum 13 12 Aug 2011 12:25 pm
