This is leaking. Help me find out where it goes to?
Old 01 Jan 2012, 03:35 pm
Default This is leaking. Help me find out where it goes to?
Hi there,
Can somebody help a someone real to cars find out what this hose is for and where is going? I found out my mother's PT Cruiser is leaking something and I found this hose loose. It seems likes it's supposed to be clamped but I can't tell what it does. Can you guys help?
Old 01 Jan 2012, 04:20 pm
UptownSport's Avatar
Default Re: This is leaking. Help me find out where it goes to?
High Pressure Power Steering hose?
rockauto .com has it for $30. I looked up a 2003 (just guessing) says it fits non-turbo 03-09
Old 01 Jan 2012, 04:26 pm
And you'll need 'line wrenches' to remove, it'll be very, very fun
Old 01 Jan 2012, 04:42 pm
I'm going to have to buy some duct tape.
The installation look painful. It says you have to move the A/C compressor!
Old 01 Jan 2012, 04:59 pm
There was a recall on the 2001-2005 cruiser for that hose rubbing against the transaxle case and maybe causing a fire. I'd look to see if your PT had that recall done. If that's the cause of the leak it will be fixed for free.
The power steering pressure hose on your PT Cruiser (VIN: xxxxxxxxxxxxxxxxx)
may contact the transaxle dif ferential cover. Prolonged power steering hose
contact can cause the hose to rub through and leak power steering fluid. Power
steering fluid leakage in the presence of an ignition source can result in an
underhood fire
Old 01 Jan 2012, 06:36 pm
Thank you all very much for the help! I was freaking out a little because it seemed like a lot of work for something so simple.
Crewzin: Thank you for the tip. I checked but Chrysler's website says that my car was not included in the recall. Bummer.
On closer inspection, it seems that the hose is not ruined it's just that the clamp is no longer holding it. Here is a picture:
I'll give it a try and see if I can put it back together.
There is also a screw missing right next to the transmission fluid pan. I don't even know what kind of screw. Anyone knows what it is?
Once again thank you for your help. I feel it's necessary to learn about your cars even if you end up using a professional so I really appreciate the education!
Old 01 Jan 2012, 06:59 pm
I don't think your missing a screw. I believe that's where they screw something in to hold the casting when they make the mold for whatever part it is. Something like that. I'm missing it also and all the pictures I can bring up of the undercarriage has the same hole. Maybe it's where they screw some sort of jack when they drop the engine/transaxle. That seems more likely.
Old 01 Jan 2012, 07:18 pm
Is that a big dent in your mom's tranny pan??? Maybe she's hit something and that's causing these issues?
Old 01 Jan 2012, 08:43 pm
That black rubber sleeve is supposed to keep the one metal clamp from rubbing on the hose and it appears the mark on the hose may be a wear mark. Unfortunately,this is a high pressure hose and duct won't hold the pressure. If you wipe off that area to get it dry, start the car and run the steering in both directions and then check to see if fluid leaks anywhere after you turn it off, you will see fresh power steering oil there if the hose is leaking. Also, your power steering fluid should be getting low.
And Chromenut is right. That is a wicked hit to the transmission pan. You will need to dry that area very well. Use parts cleaner, brake cleaner, or even paint thinner and confirm you don't have a little leak right at the dent.
Old 01 Jan 2012, 09:27 pm
Crewzin: I just assumed that I was missing some sort of plug because the fluid leak appears to be around that area. Thanks for setting me straight. One less thing to worry about.
Chromenut: I noticed the dent but it didn't seem to me at the time to be a big deal. I'll definitely take a closer look.
cjb15:Thank you for the instructions! I'll follow them and see if I find the leak. The steering fluid doesn't seem to be disappearing but just looking at the photos, it does look like liquid is spraying around that hose. It would really suck if it was the hose because the procedure seems to be really long and complicated. Hopefully the problem is the pan.
Leaking red oil jsparr Tech & Performance Forum 8 04 May 2011 09:55 pm
A/c compressor leaking? captmeach7 General PT Cruiser Discussions 11 10 Jul 2010 04:55 pm
Leaking oil cap? CreepyPT Tech & Performance Forum 3 29 Oct 2009 12:16 am
Oil Leaking kairobsor Tech & Performance Forum 4 30 Aug 2009 01:10 am
oil leaking ptma767 General PT Cruiser Discussions 11 20 Feb 2008 07:42 pm
