2006 Manual Touring Ed
Old 05 Jan 2012, 02:48 am
Question 2006 Manual Touring Ed
Hi,
When the clutch is fully engaged in 1st or 2nd there is shudder (stutter) when it's released. Any ideas?
Thanks in advance for your input
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 05 Jan 2012, 04:03 am
Default Re: 2006 Manual Touring Ed
Hmm sounds like possible motor mount issues.
Old 05 Jan 2012, 08:18 am
davea300's Avatar
Mine does the same. My upper and lower torque struts (engine mounts) have a lot of free play, think I need to replace them. If you start the car and put the stick in neutral do you feel any vibration at all? My car had a slight shake and judder when sitting at traffic lights.
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 05 Jan 2012, 01:33 pm
UptownSport's Avatar
Get a tube of 3M windshield urethane, fill voids in upper and lower arms;
see if this 'cures' it.
Old 05 Jan 2012, 03:43 pm
davea300's Avatar
Just read your other posts about using 3M on the engine mounts. Sounds a good fix. Would this stuff be similar to the 3M one you mentioned? (3M seems to be hard to come by in the UK).
Sika Flex Sikaflex 255FC adhesive body kit windscreen | eBay
67,000 miles
Old 05 Jan 2012, 10:08 pm
I assume if it holds windshields it's the same idea-
Neon guys have used hot-glue, they say it works, but I've never tried it.
Old 05 Jan 2012, 10:46 pm
Both the 3m and Sika Flex are PolyU, so probably very much alike. As to the hot glue, it's not got the give of Poly, so if you use it you'll notice a lot of vibrations from the engine will be transferred to the cars body/frame. So you'll feel more with the hot glue.
Old 06 Jan 2012, 04:32 am
davea300's Avatar
Might give it a go as its much cheaper than 2 new mounts. They are the equivalent of $120 to buy here for both.
67,000 miles
Old 10 Jan 2012, 08:31 am
davea300's Avatar
Ok I'm off to order some Sika Flex.
Do you recommend taking the engine mounts out to fill them or can you manage fine with them in place. I was just going to do the latter as they are easy enough to access.
67,000 miles
Old 10 Jan 2012, 12:20 pm
Take them out-
You can use the oven (@ like just above ambient; warm) to cure them faster.
2005 PT Cruiser Touring Edition Manual Low Milage Selling Cheap hushpuppy Classifieds: For Sale/Trade 7 23 Sep 2011 06:54 pm
2006 5 spd Manual transmission question discovering06 Tech & Performance Forum 10 28 Dec 2010 01:57 am
Manual Transmission issues 2005 PT Touring azptowner Tech & Performance Forum 4 14 Oct 2010 02:42 pm
01 PT / Touring - manual transmission shifter cables fianafail Tech & Performance Forum 2 17 Sep 2010 08:32 am
06' PT CRUISER TOURING/TURBO OWNER MANUAL CATLADY Classifieds: Want To Buy 0 27 Jul 2010 02:14 pm
