Another rough idle / P0303 Code thread
Old 07 Jan 2012, 10:45 pm
Default Another rough idle / P0303 Code thread
Hello fellow Cruiser Owners.
My 2004 Cruiser (105,000 miles/non turbo) has the rough idle/P0303 code syndrome. Check engine light flashes while sitting on idle, solid check engine light while driving.
I've had the spark plugs and wires replaced, PCM updated at the dealership ($115.00) to see if that helped, as I've read that there was a TSB indicating that an update on PCM could possibly fix. Still rough idle, still P0303 code.
Dealer wanted another $115 to run a full diagnostic on my cruiser, to see if it was the PCM itself that was malfunctioning and in need of replacement. I declined the full diagnostic as the dealer said that the possibility of the PCM to be at fault is very high and I can purchase a refurbished PCM on the web for $199 and replace myself rather than pay the dealer to replace (but I am waiting to see if I can do other lil repairs prior to having to buy the refurbished PCM.
This weekend I will be taking my cruiser to the shop to have a compression test done and see if its a burnt valve or injector that is causing the rough idle. I'm having him check for vacuum leaks as well as I read that it can also be the cause for the poor idle.
I've read about the carbon deposits that are also common amongst cruisers and dumped a slick50 fuel treatment on a full tank of premium fuel and hope that does something for this problem while I wait for my mechanics visit next weekend.
Anything else I've missed that I can do?
Done list:
- PCM updated
- Spark plugs replaced
- Spark plug wires replaced
- Fuel injector cleaner
- High and Low fan relay replaced (cause I have the "A/C makes my Cruiser stall while on idle problem" idk if that has fixed it as I'm not currently using the A/C)
To do list:
- Compression test
- Vacuum leaks to be checked
- PCM possible replacement
- Maybe throttle position sensor replacement
- Timing belt and water pump will be replaced also very soon as I have 105k miles on it :/
BIG FAN of this Forum, I'd appreciate any advice for my precious wagon!
Old 08 Jan 2012, 12:19 am
Default Re: Another rough idle / P0303 Code thread
Did you take the throttle body out and cleaned it? specially the IAC ?
Old 14 Jan 2012, 01:31 pm
Well, I have checked for vacuum leaks, spark plugs, spark plug wires and the IAC, they all check out fine, still rough idle, did compression test and found that cylinder 3 marks at 90 on the gauge versus 180 of cylinder 1 and 2.
I was told by my mechanic that the engine is going out basically
I think that its time for the wagon to be sold...
Old 29 Jan 2012, 12:17 am
Ok, so I'm not selling my wagon! With my tax refund I am aiming to have valves checked and rebuild my engine if necessary, since the compression of cylinder 3 is 90 units below the other cylinders. So I should have a great Cruiser with a rebuilt engine shortly.
How much would that run me on average? I'm in California.
Old 30 Jan 2012, 03:42 pm
With over 100,000 miles, you need timing belt and water pump replaced anyway, ballpark $1,000. With belt off have them take off the head and see what's wrong - probably valves. Rings usually aren't the problem, must likely valves either burnt or not seating right.
Old 01 Feb 2012, 08:39 am
Thanks quicksilverdon, yeah I'm hoping that it is a valve problem, Cruiser has been in the shop all day yesterday, hopefully I get some good news today, it's with a trustworthy mechanic, so I am sure that whatever it is that's wrong will be an honest diagnostic.
I will be having the timing belt replaced and other miscellaneous preventive maintenance parts replaced as well.
Code P0303 psfponies General PT Cruiser Discussions 10 29 Mar 2012 09:04 pm
Error Code P0303/Check Engine Light ohiomas Tech & Performance Forum 1 10 Apr 2011 02:47 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Malfunction Indicator Light & Code P0303 NewPTCruiserInPA Tech & Performance Forum 4 05 Jan 2009 08:12 pm
help with P0303 diagnostic code jonesfam7 Tech & Performance Forum 2 22 Dec 2008 12:49 am
