TDC mark on oil pump housing HELP
Old 08 Jan 2012, 12:57 pm
Default TDC mark on oil pump housing HELP
How do u find the timing mark for the oil pump housing I'm not seeing it. it's a 2.4 2001
Old 08 Jan 2012, 08:09 pm
UptownSport's Avatar
Default Re: TDC mark on oil pump housing HELP
It cast into that housing- Prolly a little larger than two of these fonts.
Here's an image from google:
You can ask Chromenut for the Factory Service Manual or google
'PT Cruiser FSM download'
I'd guess detailed pictures are posted by one of us in the 'how-to' links atop this forum.
Old 09 Jan 2012, 12:33 am
Thank u, I have the motor still in the car so it's hard to see it.I was thinking that I could lower the driver side of the sub-frame to help get the motor up some more and I still could not find the marks and now the wife is getting on me
Old 09 Jan 2012, 03:08 pm
That pic is of a Neon, BTW (reason for funny looking old-school tensioner), but marks the same. I looked thru my pic archives and have never taken a pic of it-
It's a ways back, but you should be able to see it. I do know you can get confused, not because mark is obscured, but it's hard to get a straight-on view to line up pulley mark andarrow.
If not, remove #1 S-plug and drop a LONG screwdriver in there- You should tell when it dwells at TDC
You do have pulley and outer timing cover off???
Old 09 Jan 2012, 04:23 pm
Old 09 Jan 2012, 11:36 pm
Thank you so so much I took the head light out and can see the mark really good now
Old 11 Jan 2012, 11:11 am
wheelgarage's Avatar
To see it clearly, when lining up the t-belt, I used the yellow paint pen and marked it. It made it soo much easier to see...
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Timing mark question on a non turbo. chigger_ns Tech & Performance Forum 4 07 Jul 2010 04:48 pm
TIMING MARK SCREWUP shammesfah Tech & Performance Forum 0 28 Mar 2010 10:14 am
scuff mark onyx pt The Detail Shop 2 04 Aug 2004 12:53 am
congrats gary!! broke the 1,000 mark!! bobs turbo pt General PT Cruiser Discussions 7 03 Nov 2003 11:40 am
mark your calendars!!! Daniel Southeast PT Forum 2 04 Oct 2003 11:59 am
