How to disconnect IAT plug
Old 09 Jan 2012, 08:59 am
Default How to disconnect IAT plug
2005 Turbo.
Want to install new spark plugs and spark plug wires. Need to unplug the IAT, but am stymied.
Found the little red tab and pulled it out toward IAT harness. Plug still seems locked on though I can wiggle it. If I loosen the little black side tabs on the side of the plug ,it doesn't loosen the plug.
Is there some other release mechanism on this little bugger? Don't want to break anything.
Think I figured out how to remove the throttle and cruise cables and the plastic trim cover over the manifold. Just can't get that IAT plug off.
Old 09 Jan 2012, 12:26 pm
Default Re: How to disconnect IAT plug
TTT. Hope you folks can guide me on this.
Old 09 Jan 2012, 02:55 pm
UptownSport's Avatar
Not familiar with turbo model, but there is a 'press' tab on all sensors.
Push it on slightly to release tension on clip, then depress, then pull.
Old 20 Jan 2012, 02:47 pm
reevescajr's Avatar
Originally Posted by dshiel View Post
2005 Turbo.
I don't seem to have an Inlet Air Temp (IAT) on my 2003 Turbo, but there is a connector on the MAP sensor that sounds suspiciously like the one you describe. I'm including a photo below.
But I'm having the same trouble with it as you are with the IAT. I have a background in electronics and have not been able to get the friggin' thing off. The black plastic thing with tabs on the sides at the back is just a cable clamp to hold the wires in the connector. The white nylon tab in the center on the top at the back catches on the red plastic tab inside the nylon connector housing. Pressing down on it releases the catch, which in my thinking should allow you to pull the connector off. Maybe it is just stuck, but like you, I don't want to break it. Not sure how you managed to pull the red tab back, but if it is pulled back, the nylon tab wouldn't be caught on it anymore and the connector should come off.
Maybe a kind soul will respond with some help here...
Old 20 Jan 2012, 03:01 pm
From Haynes:
Old 20 Jan 2012, 03:27 pm
reevescajr's Avatar
Thanks for the prompt and thorough reply. I thought that was how it was supposed to work, but in my case the red tab won't slide back w/o lifting it off the nylon tab inside the connector with a small screwdriver. The connector then slid right off when I pressed the nylon tab.
BTW, the reason I tried to remove it was because the service manual said I had to when changing the plugs. I managed to work around it and get them changed with no problem. Well, none other than the oil in the #1 plug chamber, off topic here and discussed in another thread on this forum.
Old 20 Jan 2012, 04:48 pm
On any / all those red plastic 'locks', just remove them. The connector won't come off accidentally.
I do wonder the reason for these- near all connectors have them, obviously the injector connectors do, but if you pull a 2.7 intake (Injectors are literally 'buried' under the manifold) they don't have them.
Leads me to believe it's a type of 'tamper-proof' for dummies or something.
Connectors will break when they get old/ hard trying to get these off.
Old 20 Jan 2012, 08:06 pm
mdfrodolives's Avatar
I think you can just pull and gently twist the entire sensor from the air hose. There is no grommet--but be easy with it.
Tim
Old 20 Jan 2012, 08:48 pm
Tim
True, there's no separate grommet, it's built into the ribbed hose. I've taken the whole sensor out many times. BUT be careful, the small red tip of the sensor that's inside the ribbed hose is easy to break off and if it does, the whole sensor needs to be replaced and I think someone said you have to buy the sensor with the wiring harness.
Old 21 Jan 2012, 05:50 pm
[ changed with no problem. Well, none other than the oil in the #1 plug chamber, off topic here and discussed in another thread on this forum.[/QUOTE]
Now would be a perfect time to install a valve cover gasket set to cure this with all the stuff you have off all ready. Just say'n
2006 PT Cruiser - How to disconnect the horn so can use the car! uley1929 General PT Cruiser Discussions 13 18 Mar 2013 02:09 am
Fan Relays - How Do You Disconnect Them? AlphaBob Tech & Performance Forum 5 09 May 2011 01:43 pm
How to Disconnect Factory Alarm 02 Pt TPB Sound and Security Forum 4 04 Mar 2008 12:47 pm
Negative battery terminal disconnect necessary? KingKole02 Sound and Security Forum 11 16 Feb 2004 03:12 pm
