transmission soleniod assembly
Old 12 Jan 2012, 12:47 pm
Default transmission soleniod assembly
anybody know anything about this part. my pt was leaking trans fluid and my mechanic replaced this. its leaking again so i need to take it back any suggestions
Old 12 Jan 2012, 01:33 pm
Default Re: transmission soleniod assembly
I believe you need to take off the air filter and battery.
Old 12 Jan 2012, 02:26 pm
RaineMan's Avatar
I believe mine is leaking from the solenoid as well... only does it when it is really cold or has sat for several hours. Always seems to leak overnight, never while I am at work. I keep a check on the fluid level and it hasn't visibly changed yet... so only minor seepage. I'll probably get it replaced this spring when it isn't 20 degrees out.
03 2.4L turbo Fan Assembly Help LMac General Turbo Discussions 9 17 Nov 2011 05:48 pm
Fan Assembly bnicolet General PT Cruiser Discussions 1 27 Feb 2011 05:01 pm
Sunroof assembly Freezinghot Exterior Accessories Forum 8 14 Jan 2011 11:02 am
What if the Watts assembly goes bad? edb PT Cruiser Convertible Forum 5 18 Oct 2010 08:02 pm
Headlight assembly for the PT cutter Exterior Accessories Forum 6 02 Jul 2003 07:04 pm
