07 pt cruiser no spark or injector pulse
Old 12 Jan 2012, 02:48 pm
Default 07 pt cruiser no spark or injector pulse
good day everyone. ok here goes, i have an 07 cruiser 2.4 non turbo, i have no spark or injector pulse. on my solus scanner as i crank it it shows cam and crank sensor in sync but a 9 or so degree difference. does mean the timing belt has slipped and causing my woes? i thought that until i checked and it looks to be in time. no dtc's whatever. check and verified asd relay is working correctly. all fuses are good. i unplugged all sensors, injectors and coil and receive a dtc for all. plug all back in one by one and the dtc's go away. any ideas would be helpful. thanks in advance
Old 13 Jan 2012, 09:30 am
Default Re: 07 pt cruiser no spark or injector pulse
anybody?
Old 13 Jan 2012, 10:02 am
Over 40 people looked at your problem but I guess, like me, are as stumped as you are. The only thing I can suggest is that the Camshaft or Crankshaft sensor might be a problem. They both work in telling the computer when to send spark from the coil to the plugs. You can crank the ignition all day but if one of them is bad, no spark.
http://forums.bimmerforums.com/forum...d.php?t=971792
Old 13 Jan 2012, 10:41 am
have verified both are sending signals to the pcm. looks like a pcm will have to be ordered. thanks everyone
Old 13 Jan 2012, 11:02 am
RaineMan's Avatar
Yeah... I was thinking cam positioning sensor myself. Those things are known for going bad.
Even if your timing was off you would still be getting spark and fuel pulses... they would just not be synched properly. I would venture a guess that a complete failure is something electrical related.
UptownSport's Avatar
I'd ask why it's in synch but 9 degrees out. This contradicts.
You'd need to find TDC then pull upper timing cover and verify cam alignment.
On Neon, cam misalignment will turn off ASD.
It will run on all but one year w/o cam sensor, dunno about PT.
Old 13 Jan 2012, 11:16 am
quick question, when the asd relay energizes the middle wire on the coil should the power be feeding back to the pcm thru the coil 1 and coil 2 wires?
Old 13 Jan 2012, 04:20 pm
Hope somebody comes along and answers your question. It's way over my head. The Haynes and Chilton manuals have schematics but doesn't get that deep into the whole system.
Old 13 Jan 2012, 06:13 pm
thanks alot anyway. i think the pcm is toast, but its not affecting anything else
Old 13 Jan 2012, 07:09 pm
This is from Neon experience;
Center wire is positive from ASD (Sounds like you already know this)
other two wires are grounded by PCM as needed for spark- It's 'wasted spark' or 'batch fire' not sequential (why there's only two ground wires)
IF cam and crank are far enough out of synch, PCM won't turn on ASD.
THE FSM would have that specific number, IOW, would 9 degrees be enough to disable ASD.
There's an initial ASD to prime fuel pump, but it stops until cranking.
Injector question OurPTGT Tech & Performance Forum 1 11 Dec 2011 08:10 pm
01. pt cruiser no spark gjason49 Tech & Performance Forum 1 03 Jul 2011 04:08 pm
Help no spark 2002 pt cruiser zackkbcobra Tech & Performance Forum 14 27 Jun 2011 03:27 pm
injector question? 03greygtcruiser Stage Turbo Kits 3 13 May 2008 09:46 pm
Fuel Injector American flyer Tech & Performance Forum 7 14 Jan 2003 12:56 pm
