water pump replace question.
Old 12 Jan 2012, 04:11 pm
fabreezai's Avatar
Default water pump replace question.
Has anyone replaced their water pump without having to remove the cam sprockets to get the timing belt back cover off? can it be unbolted and moved over enough with out removing the sprockets? I'm doing the timing belt and pulleys while I'm there.
Thanks guy's
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 13 Jan 2012, 01:59 am
wheelgarage's Avatar
Default Re: water pump replace question.
The cover will need to come off in order to remove the pump.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 13 Jan 2012, 08:36 am
compdr59's Avatar
You will need to remove it. You should also replace the cam seals. You really don't need any special tools to remove or install them.
I purchase an inexpensive cam gear holder from Harbor Freight. It worked fine.
Original Owner 135k
Old 13 Jan 2012, 10:36 am
UptownSport's Avatar
You can just use a socket and extension to lock cam gears while loosening bolts
And the photo is wrong, I think it's now 10mm
Old 13 Jan 2012, 09:49 pm
fabreezai's Avatar
Thanks for the reply guys!
Will be starting on it this weekend, no rush, not trying to get it done in record time. Will be posting on progress.
Thanks again for the info guy's!
HELP - cam belt and water pump Jassy Tech & Performance Forum 3 21 Apr 2011 09:23 am
Water Pump rute66pt General PT Cruiser Discussions 4 03 Dec 2009 01:56 pm
Cost to replace power steering pump? djfox1 General Turbo Discussions 4 24 May 2009 07:42 am
Water pump leaking at 38,000, have a question... Rumble Tech & Performance Forum 8 30 Dec 2008 07:12 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
