rack and pinion replacement
Old 13 Jan 2012, 12:54 pm
Default rack and pinion replacement
Does the steering wheel need to removed to get the rack and pinion out? I have a hayes manual and it's calling for the steering wheel removal. I have a garage manual that doesn't state anything about steering wheel removal. Also, does the roll pin get removed when the cross member is lowered or from in the car? Other then that it looks pretty straight forward.
Old 13 Jan 2012, 01:29 pm
Default Re: rack and pinion replacement
Is your rack and pinion leaking?
Old 13 Jan 2012, 01:40 pm
indeed it is sir....I put sealer in it a few weeks ago and had to do it again yesterday. I feel I am on barrowed time untill it needs to replaced. I got a replacement Rack and Pinion yesterday and have a nice heated garage to do it in. I already did the lower control arms, ball joints, bushings, sway bar and connecting rods. I guessing it's a good time to do the tie rod ends.
Old 13 Jan 2012, 07:29 pm
UptownSport's Avatar
This is for Neon:
There's a really funky nut to disconnect the stub from the steer column, there's the roll pin to remove that same stub from the rack.
Here's what a Neon (manual, this is rare boys!) stub looks like:
Here's the Neon funky nut (Courtesy a Neon Buddy)
There's no reason to loosen the steering column on the Neon, nonetheless, it isn't difficult (on Neon) just wrap steering wheel tight to steering column with duct tape so it can't turn!!!!
Rack and Pinion CherylK Tech & Performance Forum 7 18 Nov 2009 02:28 pm
look for rack and pinion feefeethaflee Classifieds: Want To Buy 0 30 Oct 2009 11:21 pm
rack & pinion chromer don Wheels, Tires, Suspension 0 26 May 2008 10:22 am
RACK AND PINION ~ Help R_I_PT Tech & Performance Forum 11 31 Oct 2007 04:03 pm
Rack & Pinion Rockdiggety Tech & Performance Forum 3 19 Oct 2005 10:49 pm
