Timing Belt Replace- What parts, brand/
Old 16 Jan 2012, 03:50 pm
Default Timing Belt Replace- What parts, brand/
I have a 2002 Limited with 101,900 miles & ready to replace timing belt. Some have said to replace water pump at same time, my question what actual parts should I get & what brands, part houses, do you use?
Old 16 Jan 2012, 04:18 pm
Send a message via AIM to Afton
Default Re: Timing Belt Replace- What parts, brand/
I cant speak on the water pump but after workng for Gates for 17 years I would go with a Gates timing kit and belt. I am sure others can advise you as well.
Larry
Old 16 Jan 2012, 04:19 pm
cruserdad1976's Avatar
gates is always a good choice and as far as the WP some say a MOPAR is best im not sure but its not a job you want to do over
Old 16 Jan 2012, 04:31 pm
I used a Gates kit on my wife's 02 N/A and I had no problems...and it came with the good water pump (made in japan)
Old 16 Jan 2012, 04:36 pm
go to RockAuto Auto Parts and put in all the information about your PT and look under "timing belt'. You'll get lots of choices for parts and kits that have everything you need.
Lots of us have used their parts and have had no problem with prices and shipping.
Old 16 Jan 2012, 05:15 pm
Thanks for the info. Looked on Rockauto under timing belts & found a Gates Timing Belt Component kit which includes water pump for $109.79 plus shipping. I had noticed in some posts about getting a new design tensioner, the info on the timing kit says it replaces OE parts. This ok?
Old 16 Jan 2012, 05:17 pm
That's the same kit I used
Old 16 Jan 2012, 07:04 pm
fabreezai's Avatar
IMHO- Get the kit that comes with the pump, Idler pulley, belt and tensioner. In addition get the 2 cam seals and front crank seal while your in there. Some say if they are not leaking don't worry about it, I say while you are there do it and know they are good. As you'll find out, it's a BI*CH to do the belt and you have access to those seals while your there. Other wise if they start leaking you'll have to go through the whole process again to do them. They are only about 6-8 bucks a piece.
Just my 2 cents.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 16 Jan 2012, 10:40 pm
compdr59's Avatar
Don't forget the drive belts and the idler that goes on that tensioner. Just a little insurance while you have everything apart. You will soon find out that your torque struts are shot too. I replaced the middle motor mount too, but it's not the one that wears out.
Original Owner 135k
Old 23 Jan 2012, 11:52 am
Send a message via MSN to niel
gates its the brand for timing... or serpentine or acces belts
"I AM THE DIGITAL SIGNAL PROSESSOR"
Timing Belt Parts list bobdole369 General PT Cruiser Discussions 1 25 Jan 2010 04:01 pm
When to Replace Timing Belt georgiapt General PT Cruiser Discussions 19 22 Jun 2009 11:49 am
timing belt BRAND??? mtnbktrek General Turbo Discussions 3 08 Mar 2009 09:45 pm
Need infor on how to replace timing belt dbcox General PT Cruiser Discussions 4 10 Feb 2009 08:00 pm
