............Heater Problems..............
Old 16 Jan 2012, 10:13 pm
Default ............Heater Problems..............
Has anyone had any problem's with their heater during the cold month's as I have had problem's getting little or NO heat during these cold mo's. I've had my pt heater core flushed out many of times and I get heat for alittle while then it gose back to very little if none at all...Any suggestion's.......
Old 16 Jan 2012, 10:34 pm
Default Re: ............Heater Problems..............
A lot of No Heat problems are caused by trapped air in the coolant system. Make sure you purge all air out of your system.
Heater smell discovering06 Tech & Performance Forum 5 23 Dec 2016 12:31 pm
Heater & A/C does not blow air gemini6609 General PT Cruiser Discussions 8 03 Nov 2011 06:50 am
Block Heater? Sarasmiles Tech & Performance Forum 7 14 Dec 2010 04:32 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
Heater problem dwallace PT Cruiser Convertible Forum 16 15 Jan 2008 08:23 am
