Changing Timing Belt - Jack engine end?
Old 17 Jan 2012, 02:09 pm
Default Changing Timing Belt - Jack engine end?
2006 Cruiser Nonturbo
Can I jack up just the timing belt end of the engine to access the mount bolts without unbolting the transmission mount? Or will this damage the transmission mount?
Thanks in advance.
Old 17 Jan 2012, 02:53 pm
Default Re: Changing Timing Belt - Jack engine end?
You should jack up the passenger side and lower the transmission side. So, yes you'll need to disconnect the transmission mount.
Old 17 Jan 2012, 09:11 pm
UptownSport's Avatar
I somehow did it w/o unbolting trans mount, of course disconnect the exhaust flange.
Thought I followed the FSM, but anything I recall's debatable.
rough idle after changing timing belt CJDoble Tech & Performance Forum 7 30 Jul 2015 08:59 am
Poor gas mileage after changing timing belt, water pump and radiator??? fduffy28 Tech & Performance Forum 0 02 Apr 2011 04:05 pm
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
rough idle after changing timing belt on 01 pt EnragedDolph Tech & Performance Forum 2 13 Oct 2010 03:51 pm
