Timing Belt Replacement - What Next?
Old 17 Jan 2012, 05:32 pm
Default Timing Belt Replacement - What Next?
I have 102,000 on my 2002 Cruiser Limited & ready to replace timing belt & water pump. What other kinds of issues might I encounter with this kind of mileage on my vehicle. It has been good so far.
Old 17 Jan 2012, 05:39 pm
cruserdad1976's Avatar
Default Re: Timing Belt Replacement - What Next?
frount wheel berings radiator fan rotors breaks watts link motor mounts these come to mind
Old 17 Jan 2012, 05:54 pm
Chrysler upgraded the timing belt tensioner in 2004. You might also want toget the new one with the belt change. While your in there. The serpentine and alternator belt is a good time to change.
Old 17 Jan 2012, 06:31 pm
the radiator hoses could be changed as well as the thermostst
Old 22 Feb 2012, 04:57 pm
Welcome. I try also to the timing belt replacement. By the way, I ask - I do not want to assume a new topic specifically. Does the belt replacement is difficult, if not cause problems. Maybe you have a description of the exchange?
Old 22 Feb 2012, 05:22 pm
Hey, I think I understand that.
If you go into the Tech & Performance section of the forum, look for the thread entitled: HOW TO. When you open that, there's about 2 dozen threads on how to do many things on the PT. There's about 3 or 4 of those threads that talk about the timing belt change. Have you worked on cars where you come from? The timing belt change is a long, complicated and sometimes frustrating job and even the best sometimes have problems. Good luck.
Timing Belt Replacement MarkB Tech & Performance Forum 108 08 Aug 2017 12:59 am
Timing belt replacement snakepitt1 Tech & Performance Forum 10 18 Dec 2016 12:17 am
Timing belt replacement??? HELP!!! CRFDAD Tech & Performance Forum 4 07 Jan 2009 08:14 am
Timing Belt Replacement? Kawika Tech & Performance Forum 14 15 Dec 2007 11:56 pm
Timing belt replacement? mojogator Tech & Performance Forum 3 12 Nov 2003 03:30 pm
