Need help with error code P0138
Old 18 Jan 2012, 01:38 pm
Default Need help with error code P0138
Hi,
My car is getting the error code P0138. I checked that it is about the O2 sensor. Some people saying it is upstream, while others saying it is downstream. I was trying to look for the O2 sensor on ebay and see some 5 digit number like 231xx. My vehicle is 2003 Dream Cruiser with manual transmittion. I think it is the similar to a 2003 GT. The questions are:
Which sensor should I buy?
Is it upstream or downstream?
Is there any instruction to replace the sensor?
Is it an easy job or I need some mechanic to do it?
Thank you.
Old 18 Jan 2012, 05:43 pm
VNT's Avatar
VNT VNT is offline
Default Re: Need help with error code P0138
IMHO
Buy Mopar O2 sensors, or your asking for problems.
The reason is they have fast sample response time , and if you go and get after market they may not respond as fast and will trigger codes and cause all kinds of issues.
Call the dealer and get the part # and go on line to one of the mopar online centers to save a few bucks but e-bay is not your friend.
Replace both sensors and they can be stubborn and awkward to get out so if your not a DIY, pay someone.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 19 Jan 2012, 12:43 am
UptownSport's Avatar
This JUST came up- Crewzin, (IIRC) explained which sensor the code referred to.
Sorry I don't recall the specifics.
I do know the old Neon downstream was only to check Cat performance, not to give info PCM could use to adjust engine parameters.
Old 19 Jan 2012, 08:37 am
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
The PT Cruiser only has one "bank". The code is generic for ours and the V8 engine which have 2 banks (one per side). My Vette has 3 02 sensors, one on each exhaust manifold and 1 by the CAT. So the tech and tell which sensor is bad the code tells him "Bank 1", (drivers side) or "Bank 2" Passenger side.
So forget the "Bank" part of the fault code readout on the PT.
Sensor 1 (on the PT) is on top of the exhaust manifold.
Sensor 2 is on the left side of the Catalytic converter.
Old 27 Jan 2012, 11:52 am
Thanks for all the input.
I am the kind of DIY person if I have the instruction. I did a few research and found that to replace the O2 sensor is like plug and play. However I could not see clearly in the pictures above. Are the sensors under the hood or under the vehicle? It will be tough for me if they are under the vehicle since I do not have the equipments.
Old 27 Jan 2012, 03:32 pm
Both-
Upper is behind the engine, in the engine compartment
Lower is on the side of exhaust right after catylitic converter.
You can drive vehicle over a hole or depression, or one wheel up on and object so you can crawl under.
If wheels blocked sufficiently this is actually safer than jacking it up and crawling under.
Old 29 Jan 2012, 08:00 pm
Travis2k7's Avatar
I took this advice with the same code a couple years ago and changed sensor 2. The code has never come back.
2006 Limited, Auto, 100k miles
Old 31 Jan 2012, 04:20 pm
The wierd thing is that the engine light turned off for about a week. The error code appeared when the temperature was below 30 degree. It is back to about 0 degree now. Does it mean the sensor is working?
Thank you.
P0138 error code on a 2004 B P.T. cruiser jcb1972 General PT Cruiser Discussions 0 10 Oct 2010 09:43 am
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
Error code 601 COOLSILVER02NV Tech & Performance Forum 7 14 Jul 2009 10:52 am
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
