Can't get error code
Old 19 Jan 2012, 10:55 am
Default Can't get error code
I just got an engine light, and did the key on and off to see the code number, but no luck.
2005 turbo!
Sequence was off/on, off/on, then on, all within 5 seconds.
I also saw the example on You Tube which was the same sequence.
Any comments as to why it's not showing?
Thanks
Old 19 Jan 2012, 11:17 am
Send a message via Yahoo to echillie1
Default Re: Can't get error code
it will show sometimes it takes a few tries,you have to wait a little bit before they start showing,ready with a pen & paper .
Old 19 Jan 2012, 12:46 pm
Actually, its: on/off, on/off, on. Since you start at the key in the off position. As was just said, keep trying.
Old 19 Jan 2012, 08:57 pm
I must have done it with the car in reverse LOL.....
I will try the on off sequence.
Thanks
Old 19 Jan 2012, 10:50 pm
This is a video made by wolfmang and it shows you how to do it... ( make sure you lower the volume of your PC when you watch the video.. LOL)
Old 22 Jan 2012, 04:45 pm
WolfmanG's Avatar
if you do the code retrieval correctly but still don't get a code, you might want to check your tire pressure on all tires and your gas cap. take it off and put it back on and make sure you do three clicks or more. i always do like 6. if the light doesn't go away after a couple of days and your still not getting any codes, disconnect the battery for about 5 min's and then reconnect it. This will help rest the comp.
Sorry about the music on the vid by the way. lol when i recorded it, the sound didn't come out so i through on a music track instead lol.
-Danny Wolfman G
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
error code 113 BeagleDad Tech & Performance Forum 17 22 Aug 2010 01:13 am
Error Code bus b8 or 68, not sure. richardbradley Tech & Performance Forum 2 18 May 2010 07:45 pm
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
Error code?? whiteknight Tech & Performance Forum 3 15 Mar 2008 10:29 pm
