COOLANT SHOWER, need to dry off!
Old 20 Jan 2012, 08:52 pm
Default COOLANT SHOWER, need to dry off!
I have a 2003 PT Cruiser, approx 109,000 miles. Today i was driving and stopped at a stop light and all of a sudden my hood is smoking like Vesuvius on a bad day. I pull over to check out whats up and there is just coolant everywhere. under my car i looks like ol bruiser wet himself with coolant. Could this be a radiator problem or maybe a messed up hose. Im not mechanically inclined neither do i have much cash to pay for tows to a garage. Can someone pls help me out with what it could be and the best course of action! Thx Peace
Old 20 Jan 2012, 09:11 pm
Default Re: COOLANT SHOWER, need to dry off!
You pretty much answered your own questions:
It can be a radiator, a hose, water pump, thermostat housing, etc...
You don't have money for a tow or a mechanic....
but since you are not mechanical inclined , how you are going to know what to fix?
Old 20 Jan 2012, 10:06 pm
When the PT overheats, the easiest way for the coolant to get out of the system is through the overflow bottle. The plastic snap cap gives way easily and coolant flys out the neck of the bottle all over the upper manifold and down to the ground at every space around the engine. Happened to mine when the radiator fan burnt out.
Look at the overflow bottle to see if the cap is not snapped shut and that would be your indication of where the coolant came from.
That doesn't say why your PT overheated as there's a dozen ways for it to happen. You might not have to tow it if you let it cool down and add some more coolant to the radiator to get you back home or wherever you need to go.
Old 20 Jan 2012, 10:33 pm
Well. . . . I recently this week got it out of the shop because they needed to replace the thermohousing, the mechanic told me that was the issue with me hearing a boiling noise right behind the steering wheel. He said there wasn't any pressure and i had to replace the part to make it stop making the bubbly sound. This happened tuesday and i got my car back wednesday. It ran fine then, all of a sudden coolant was just everywhere like something just let it all out thank your for the help
Old 20 Jan 2012, 10:49 pm
The thermostat housing doesn't go bad so he probably replace the thermostat itself. Hopefully he bleed the system of excess air, that would cause it to overheat. I'd give him a call, tell him whatever he did the first time didn't stop the bubbling and overheating and you lost most of your coolant.
Old 20 Jan 2012, 11:03 pm
Matt42's Avatar
Make sure the mechanic puts in HOAT coolant and not Dex-Cool. Dex-Cool will eventually clog up the radiator and cause other damage. But, Dex-Cool is a little less expensive.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 20 Jan 2012, 11:38 pm
Dill's Avatar
Also feel free to replace your radiator cap if it hasnt been. Its a super inexpensive thing to get and it helps eliminate that issue (even though I doubt thats it)
Old 21 Jan 2012, 03:54 pm
If you do put coolant in it and drive it make sure you keep an eye on the temp gauge. This can go up very quick. If it dose pull over an turn it off till it cools on the gauge before going again.
The water neck that holds the thermostat in is made of plastic and do fail and could loose pressure but not with out losing coolant as well.
Coolant. Zombiess Tech & Performance Forum 4 08 Jan 2014 08:34 pm
PLz help= Coolant leak PtC06 Tech & Performance Forum 2 04 Dec 2010 02:01 am
Best Coolant For a 03 PT?? tcr1016 General PT Cruiser Discussions 4 27 Nov 2010 09:01 pm
Coolant help. pt4cec General PT Cruiser Discussions 9 15 Sep 2009 08:28 am
