Belt chirp even with new belt and tensioner
Old 21 Jan 2012, 12:02 am
Default Belt chirp even with new belt and tensioner
I have a 2001 PT with 113K. I changed the alternator belt and serpentine belt last January with I replaced my timing belt.
Now I have a belt chirp that wont go away. I replaced the tensioner last week, but the belt still squeaks. I have also adjusted the alternator belt. Before I replaced the tensioner I applied more tension with a wrench on the tensioner pulley when the car was running and the noise went away, that is why I replaced the tensioner, but it still chirps even with the new tensioner. Anyone have any suggestions? Thanks.
Old 21 Jan 2012, 04:56 am
Default Re: Belt chirp even with new belt and tensioner
A chirp usually means a pulley misalignment and in most cases it usually is the tensioner, however, you have replaced that. Hard to imagine that the serpentine belt has worn out in a year but check the wear indicator marks on the new tensioner to make sure that the belt has not over-stretched (although a loose, stretched belt usually makes a screech noise and not a chirp). Other than that, you may want to try a different brand belt. Have had good luck with Goodyear Gatorback and Dayco on my other vehicles, my PT still has OEM belt.
Old 21 Jan 2012, 06:59 am
Read this:
Belt noise
Old 21 Jan 2012, 10:16 am
Go to the Dayco Poly Rib Belt website and check out the training videos...all you ever wanted to know about belt noise.
Old 21 Jan 2012, 04:11 pm
I have washed the engine and had belts start chirping. Unfortunately the only way I'v found to fix a chirping belt is a new belt.
Old 22 Jan 2012, 10:31 pm
mdfrodolives's Avatar
I agree with Busted. I had the chirp noise on belts that had been replaced only 10,000 miles before. The belts were replaced--and I've gone another 35,000 miles and no belt noises.
Tim
Timing Belt Tensioner ? SteveG22 Tech & Performance Forum 11 19 Sep 2012 12:46 am
Timing belt tensioner Jeepertim Tech & Performance Forum 9 25 Nov 2011 12:39 pm
Timing Belt Tensioner Areus Tech & Performance Forum 0 17 Jun 2011 05:44 pm
Timing Belt Tensioner 06ptbruiser Tech & Performance Forum 11 31 Dec 2010 10:39 am
Belt tensioner love bandit2 General PT Cruiser Discussions 6 12 Jul 2009 02:00 am
