plugs & wires for a 2004 GT w/ turbo
Old 21 Jan 2012, 12:26 am
Send a message via Yahoo to echillie1
Default plugs & wires for a 2004 GT w/ turbo
Any suggestions on what's the best plugs & wires for my car its also a 5 speed if that matters.
Old 21 Jan 2012, 12:33 am
Default Re: plugs & wires for a 2004 GT w/ turbo
Read this:
Replacing plugs/wires on 2006 non-GT
Old 21 Jan 2012, 10:47 pm
Matt42's Avatar
What I use in my normally aspirated PT Cruisers are spark plugs and wires specified for a 2004 PT Cruiser turbo. I recommend them highly.
MSD wires and Autolite Iridium wires. Both are kind of spendy but I think they are worth the money.
Be sure to dab a tiny bit of anti-seize compound on the threads of the spark plug before inserting it into the head. And use some silicone spark plug boot grease on both ends of the wires.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 21 Jan 2012, 11:15 pm
Ok great ! Can I get these at any auto parts store or should I get them on line?
Thank u for your help
Old 21 Jan 2012, 11:16 pm
Thumbs up Re: plugs & wires for a 2004 GT w/ turbo
Old 22 Jan 2012, 12:36 am
Matt42's Avatar
The spark plugs will be easy to get at a parts store. The wires will be a little more difficult. I got mine online. From Amazon, I think. But Rock Auto ought to have them as well. Be sure to dab a tiny bit of anti-seize compound on the threads before you install them. And spread a little silicone dielectric grease on the insides of the spark plug wire boot ends. Both things are important, and not all mechanics do it. A parts store will have the anti-seize and boot release grease in little tubes. So will Rock Auto.
Old 04 Feb 2012, 01:32 pm
What is the gap?
Old 06 Feb 2012, 03:10 pm
Red face Re: plugs & wires for a 2004 GT w/ turbo
I replaced my spark plugs & wires last weekend with champion spark plugs & mopar wires along with an oil prerssure switch "mopar too "that had been replaced before with a aftermarket so i had it swiched out to mopar & now my car is running worse than before , it bogs out at intersections and sometimes the mph dont even read and i'm doing about 35mph,
before when all this first started i replaced my tensioner due to a rat in my motor does anyone think the tensioner could have started all these issues ??
Old 06 Feb 2012, 03:54 pm
tryingbe's Avatar
Any engine code?
85 GLH
Watch out for anchor engine mounts!!
Old 06 Feb 2012, 11:14 pm
I did the code trick a few days ago & all it said was done ,how do you know whe you need to replace the electronic control module?
Spark Plugs & Wires Recommendation For 2002 Non-turbo johnjsa Tech & Performance Forum 2 19 Nov 2008 07:47 pm
Plugs and Wires.. Ceit PT Cruiser Convertible Forum 10 26 Apr 2008 04:51 pm
07 plugs and wires freckles Tech & Performance Forum 10 18 Dec 2007 07:04 am
Plugs/wires in turbomangt Turbo Performance 1 15 Oct 2004 09:49 am
Plugs & Wires BACKinMOTION Tech & Performance Forum 4 11 Jan 2004 01:36 am
