cruiser wont start
Old 21 Jan 2012, 01:02 pm
Default cruiser wont start
2003 non turbo died on wife coming from work,had to go get her,tried jumping,battery just clicked,had towed home,check cables,put on charger,starter cranking but no start,have had no problem before,just did tuneup,have had dash lights like oil come on with no low oil,am getting power from key to starter,but battery only last a few cranks,anyone else have this problem.
Old 21 Jan 2012, 01:41 pm
Default Re: cruiser wont start
Have you actually had the battery checked to see if it's holding a full charge? If it's not putting out about 11.8 volts you'll get nowhere trying to start the engine.
Hooking another battery up for a jump start is sometimes pretty tricky. If it's not making real good contact on the positive and negative side, the charge from the good source won't get to where it needs to be.
Old 21 Jan 2012, 05:27 pm
Would clean battery post connections also. This would hamper all your previous efforts. My not be getting enough power to crank & fire engine at the same time. If your battery isn't making a good connection your boost won't ether. As CREWZIN stated in his post. After you get your battery issues taken care of and still won't start check to see if getting spark to the plugs.
Old 21 Jan 2012, 10:33 pm
Matt42's Avatar
Flooded-cell batteries are notorious for causing invisible corrosion problems in the lightweight battery clamps in use on many cars, like our PTs. They seem to emit an acid mist in the vicinity of the battery.
Beginning with the negative terminal, remove it and clean both the inside of the terminal clamp and the battery terminal. Leaving it disconnected, do the same to the positive side. But if the battery is old for your area, it would be worth getting it tested. (Around here, a flooded cell battery--even a Sears Diehard--is toast at 12 t0 20 months. They last longer in other climates.)
If the battery is good, charge it up. While it is charging, inspect the cables coming from the battery closely and carefully, from end to end, and inside the relay box. A bad connection on any of them can cause the problem you describe. The corrosion can even be inside the insulation of the cable so check carefully. If the terminals and the battery tray were a corroded mess, I suspect that may be where your problem is.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
o4 Cruiser wont start chan Tech & Performance Forum 17 25 Sep 2011 02:37 pm
07 Cruiser Wont Start! 07fastptloser General PT Cruiser Discussions 1 15 Feb 2011 06:52 am
2004 PT CRUISER wont start margarcia1028 Tech & Performance Forum 1 22 Jun 2010 07:43 pm
2004 PT Cruiser Wont Start brian_jill General PT Cruiser Discussions 12 18 Feb 2010 01:20 pm
01 PT cruiser wont start.. EvilWRX General PT Cruiser Discussions 1 12 Feb 2007 02:35 pm
