over rev when changing gears
Old 23 Jan 2012, 10:36 am
Default over rev when changing gears
So, quite new to PT ownership and a few questions/niggles to get out of the way..firstly a reving problem.
If from idle i rev the car, it almost lingers on the rev a bit longer than "normal" also when changing gear (manual) it revs a bit more than just me geting the timing wrong... almost as if the cable is sticking? is this normal or have i got an issue?
Old 23 Jan 2012, 06:32 pm
Default Re: over rev when changing gears
Normal. Eventually, you won't notice it.
Old 23 Jan 2012, 08:28 pm
yup my 03 base 5 spd does that.. i dont even notice it any more.
Old 24 Jan 2012, 04:34 am
ok cheers guys, I am gettign used to it but was a bit worried that it was sticking on or something
thanks first problem solved
Old 26 Jan 2012, 05:39 pm
TurboDucky's Avatar
Mine seems to do that worse when I have the AC on, or the defroster on in the winter. I think the computer does it to compensate for the AC compressor pull.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 26 Jan 2012, 05:44 pm
ha ha I just saw the name.. pig farmer check out my hood ornament in my photos.
Manual transmission blocking certain gears ProDigit General PT Cruiser Discussions 2 09 Nov 2010 08:18 pm
skipping gears ProDigit General PT Cruiser Discussions 12 29 Oct 2010 10:09 pm
Education Is Shifting Gears skylight PT Cruiser News and Rumors 0 14 May 2007 06:30 am
cams, cam gears?? proxeyed Tech & Performance Forum 14 18 Jan 2005 12:36 pm
Swapping autostick gears w/5 speed OVcruzn Turbo Performance 3 10 Jun 2003 12:52 am
