2005 PT Cruiser Not Starting
Old 24 Jan 2012, 05:15 pm
Default 2005 PT Cruiser Not Starting
I searched around this forum but haven't found a problem exactly like what I'm experiencing. Hopefully someone can help.
Last night my car decided to not start. I thought it might be the battery so I checked all the cables. When I reattached everything the dome lights in the car were working along with the dash; however, a bunch of weird things happened as well.
The red alarm indicator is flashing (I don't have an alarm)
The check engine light is on
The check oil light is on
The radio clock is lit up and the radio is working
This is all WITHOUT the key in the ignition. Putting the key in and turning it makes absolutely no difference. I cannot make the lights go out when I remove the key and I cannot make the car even attempt to start.
Any ideas?
Old 24 Jan 2012, 05:29 pm
Default Re: 2005 PT Cruiser Not Starting
I believe the first thing you should do is :
INTRODUCE YOURSELF before you consider getting an answer from this forum
That's the polite way to do it Didn't anybody teach you any manners?
That's just my opinion
Old 24 Jan 2012, 06:11 pm
My apologies.
My name is Mike. I'm a teacher/musician and my car is broken, lol. I enjoy basketball and playing Minecraft.
Nice to meet you.
Old 24 Jan 2012, 06:12 pm
Much better
Old 24 Jan 2012, 06:17 pm
Ok,now down to business.... to me it sounds like an ignition switch...
Old 24 Jan 2012, 06:19 pm
Yep it really sounds like it...read this
Ignition Switch Malfunction/Actuator Pin
Old 24 Jan 2012, 06:59 pm
An Innocent looking thing isn't it?
Old 24 Jan 2012, 08:35 pm
Yeah, that sounds almost exactly like what's going on. I had a suspicion that that's what it was. From the linked post it looks like it might be something I can fix myself. That is AWESOME.
Thank you.
Old 24 Jan 2012, 10:01 pm
Let us know if that fixes it , OK?
Old 27 Jan 2012, 03:42 pm
Got it all fixed. It was the ignition cylinder I believe it's called. It's basically a stupid little plastic part that the key goes into and it was cracked. Anyway, thanks again for the help.
pt cruiser dies right after starting liljjjunior Tech & Performance Forum 2 23 Sep 2011 03:40 pm
Cruiser Not Starting & Not Cruising! marylsavannah Tech & Performance Forum 3 04 Aug 2011 03:59 pm
01 PT Cruiser starting issues rampagent69 Tech & Performance Forum 1 28 Jun 2011 09:12 am
2001 cruiser not starting KingJames Tech & Performance Forum 2 21 Jun 2011 10:10 am
Pt Cruiser Not Starting teknoron Tech & Performance Forum 8 11 Sep 2008 02:04 pm
