Noisy front end.
Old 24 Jan 2012, 08:44 pm
Default Noisy front end.
My 04 GT sounds like I am running Jeep Wrangler tires on the front. No change in turns. Noise at wheel speed. Auto trans. No clicks, clanks on any other expensive noises. Bearings or transaxle? I have to do something soon. I can't turn the radio up enough to cover the noise anymore.
2004 GT Auto K&N FIPK
Stage 1
Mopar Blow Off Valve Kit
Old 24 Jan 2012, 09:31 pm
Default Re: Noisy front end.
Bearings would be my first suspect. Front or rear. Next thing would be the axle drive section in your transaxle. This also turns at wheel speed.
And what about those tires?
Old 24 Jan 2012, 11:53 pm
compdr59's Avatar
The best description of wheel bearing noise is the sound of a biplane. Now you have to figure out which side.
Original Owner 135k
Old 25 Jan 2012, 07:50 pm
I have only flown in one bi-plane (Stearman) and it was wonderful. I hope it is the bearings and not the transaxle.
Stage 1
Old 25 Jan 2012, 07:52 pm
I hear ya. Might be better off changing both. If that is the problem. Make sure ground straps are in tact. Bearings wont last without them.
New brakes are noisy PurplePTGirl Wheels, Tires, Suspension 7 08 Oct 2009 09:10 pm
NOISY ENGINE!!! ncrow02 Tech & Performance Forum 2 05 May 2008 12:52 am
Noisy Steering cruisin01 Tech & Performance Forum 4 29 Sep 2007 08:17 am
Noisy Engine... thegoldpt Tech & Performance Forum 4 07 Dec 2006 03:49 am
Noisy Terry General PT Cruiser Discussions 4 19 Jul 2002 01:41 am
