ignition system
Old 25 Jan 2012, 05:38 pm
Default ignition system
Just wondering if the sensors are considered part of the ignition system...ie crank sensor..cam sensor.....etc...etc.....thank you in advance
Old 25 Jan 2012, 06:24 pm
Default Re: ignition system
There's the:
Point-type ignition system
Electronic Ignition system
Distributorless Ignition system
Direct Ignition system.
The Direct Ignition System (DIS) uses either a magnetic crankshaft sensor, camshaft position sensor, or both, to determine crankshaft position and engine speed. This signal is sent to the ignition control module or engine control module which then energizes the appropriate coil.
Ref: Google Ignition System
Old 25 Jan 2012, 07:17 pm
Like he said, yes!
Old 26 Jan 2012, 06:18 am
Yes or no is like the best answer for a question like mine.....but thx crewzin for the detailed version. I needed this info as part of a warranty claim against a shifty car dealer.
Old 26 Jan 2012, 07:00 pm
They get paid for warranty repairs. Not as much as the customer would be charged. Go figure!
Key stuck in ignition Tabitha Tech & Performance Forum 14 23 Jul 2014 06:48 pm
%#^&&* ignition key!! wompus General PT Cruiser Discussions 19 02 Aug 2013 04:57 pm
ignition questions dtw05pt General PT Cruiser Discussions 9 05 Jan 2011 03:51 pm
msd ignition oeldisplay Tech & Performance Forum 4 19 Jan 2009 05:32 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
